000-capture.jpg file does not exists , please help
iservetech
Post by iservetech »
When I click on a link on zm console and choose to show all the events on a particular event there are random broken images, when I do a tail -f on the httpd error logs I get this :
[Mon Apr 10 15:30:56 2006] [error] [client *.*.*.*] File does not exist: /var/www/html/home/zm/4/622/000-capture.jpg, referer: http://192.168.254.154/zm/index.php?vie ... c=0&page=1
Now the interesting thing is I tared up all the jpegs under a particular event I was trying to view in the zm console and put them in the root dir of the web server /var/www/html and could access each jpeg file with no problem , however it seems that certain event id's in zm are being linked to as 000-capture.jpg when the event has been captured and labled correcly.
Like when I right click a broken image for 11/0 in say event 524 , it says is pointing to 000-capture.jpg , but when I go to the dir /var/www/html/zm and there is a file called 011-capture.jpeg , and when I move file 011-capture.jpeg to /var/www/html dir it is viewed without any problems??
jameswilson
Post by jameswilson »
Im not sure as i havnt experienced this but i think this has been posted elsewhere and i beleive is an issue with 1.22.0.
James Wilson
zoneminder
Site Admin
Post by zoneminder »
Yes, this is a know (and fixed in 1.22.1) issue.
Phil
iservetech
Is there anyway you can post a patch as a quick fix till 1.22.1 is released ?
jameswilson
from what ive gathered 1.22.1 is imminent mate
James Wilson
iservetech
1.22.1
Is there an ETA for the 1.22.1 release?
cordel
Post by cordel »
Should be out in the next couple weeks most likely alot sooner but depends on when it's ready. Phil likes to make sure the bugs are worked out and make sure no more are introduced which we all appreciate. Remember he does this in his spare time.
Regards,
Corey
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
zoneminder
Site Admin
Spare time!!?! When? :lol:
Anyway, a pre-relrease of 1.22.1 is up, see the announcements forum. I will do a full release assuming no major issues with this.
Phil
