Bad card ????
Posted: Sat Apr 15, 2006 12:41 pm
Hi
i got a BT878 card with 1 cip/4 ins - Provideo PV143
lspci :
(relevant part)
02:04.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:04.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
dmesg :
(relevant part)
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:04.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
bttv0: Bt878 (rev 17) at 0000:02:04.0, irq: 11, latency: 66, mmio: 0x40c00000
bttv0: detected: Provideo PV143A [card=105], PCI subsystem ID is aa00:1430
bttv0: using: ProVideo PV143 [card=105,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
zm is working but images are like this:
anyone has any ideea whats wrong with this ?
Thank you all.
lspci :
(relevant part)
dmesg :
(relevant part)
Thank you all.
