Screen Capture as ip cam for ZM
jameswilson
Post by jameswilson »
I have made an asp.net app that will serve jpeg's of the destop as a webpage, there is no security so it is designed for local lan use only. You basically copt the files over to your www.root on the iis server and regester the .net and thats it.
PS this requires at least ii5 i think so it win 2k and up. ANyone wants it lt me know as i havnt worked out how to save settings yet so i will have to set your settings in the code!
Regards James
James Wilson
