Page 1 of 1
System hang up
Posted: Fri Apr 21, 2006 8:16 am
by Gibbel
System: Opteron 150/nForce4, 1GB RAM
OS: Fedora Core 5 x86_64
Video hardware: 2x KMC-8800
When i open to view monitors (more that one-two) remote or local, system is hang up after some time (1-30 minuts).
Before it i use PV-143 Card and it work fine.
I can not determine it is a problem with configure my cards, or it is problem with software, cause i not find any records in logs, that can help me.
Posted: Fri Apr 21, 2006 2:20 pm
by zoneminder
When you say 'hang up' do you mean it locks up completely or can you still log in? Perhaps you can run 'top' and see if anything in particular may be using up all the cpu or memory or causing any other obvious issue.
Posted: Sat Apr 22, 2006 6:54 pm
by Gibbel
It's completely stop. Only reset is working.
It happen only when i look at monitors through HTTP. If i not do it, system work stable.
