Page 1 of 1
Ubuntu // zm-1.21.4(works) zm-1.22.0( not quite)
Posted: Fri Apr 21, 2006 10:10 pm
by jitz
Hi:
I am new to this Forum and to Zoneminder in general. I have an issue with
my 1.22.0 install. With 1.21.4 I managed to configure two monitors.
One a logitech webcam connected via usb to my PC and a second monitor
connected to a remote pc where it is grabbing frames from. Works Ok.
When I try and do the same thing with 1.22.0 I can see the local webcam
but am not getting images from the remote PC. When I downgrade back
to 1.21.4 I can again see both monitors. Does someone have an idea
of where I may start looking to resolve this issue. The monitor gets
color-coded green in both versions ( I assume that means a connection is
made/active) but when I bring up the viewer I don't appear to be grabbing
the images.
Not sure what log file or configuration I should looking at for clues to
this anomaly
From /var/log/messages I get this...with 1.22.0
Apr 21 15:32:14 localhost zma_m2[24990]: WAR [Waiting for capture daemon]
Thanks in advance
Jitz
