Upgrading from 1.22.0 to 1.22.1, the first test ok
Posted: Wed Apr 26, 2006 2:01 pm
I put the upgrade
I have A debian 3.1 kernel 2.6 and mysql 4.0.2X, with 3000 events. and one ip Axis cam.
servidorwireless:/datos/temp/ZoneMinder-1.22.1# /etc/init.d/zm stop
Stopping ZoneMinder: success
servidorwireless:/datos/temp/ZoneMinder-1.22.1# ./configure --with-webuser=www-data --with-webgroup=www-data --with-webdir=/datos/discodatos/dominios/www/zm --with-cgidir=/datos/discodatos/dominios/cgi-bin --with-mysq --with-ffmpeg --with-libarch=lib64
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-mysql option.
This tells configure where to find the MySql C library and headers if configure cannot
locate them automatically.
e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-extralibs option.
Ordinarily you will need to use this option only when your copy of ffmpeg has been built
with support for additional formats and you would use this option to detail which additional
libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
You will need to wrap this option in quotes if it contains any spaces.
e.g. --with-extralibs="-lmp3lame"
configure: WARNING: You can call configure with the --enable-debug=<yes|no> or --disable-debug option.
This tells configure whether to compile ZoneMinder with debug included. Although debug is included
by default it is not output unless explicitly switched on elsewhere. These checks may induce a
small penalty on performance and if you are after squeezing the maximum possible performance out
of ZoneMinder you may use this switch to prevent debug from being compiled in.
e.g. --enable-debug=yes or --disable-debug
configure: WARNING: You can call configure with the --enable-crashtrace=<yes|no> or --disable-crashtrace option.
This tells configure whether to compile ZoneMinder with crash tracing included. This allows a
dump of the stack trace when a ZoneMinder binary crashes or is killed by an unexpected signal.
Although this should work on most systems it does rely on un(or loosely) documented features and
so should be regarded as experimental. If you experience problems compiling zm_signal.cpp or
ZoneMinder binaries fail to shut down corrected then you should probably disable this feature.
e.g. --enable-crashtrace=yes or --disable-crashtrace
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for siginfo_t... yes
checking for struct sigcontext... yes
checking for ucontext_t... yes
checking how to run the C++ preprocessor... g++ -E
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
checking for pcre.h... yes
checking whether round is declared... yes
checking whether strsignal is declared... yes
checking whether MD5 is declared... yes
checking whether backtrace is declared... yes
checking for jpeg_start_compress in -ljpeg... yes
checking for compress in -lz... yes
checking for dlsym in -ldl... yes
checking for mysql_init in -lmysqlclient... yes
checking for MD5 in -lcrypto... yes
checking for pcre_compile in -lpcre... yes
checking for ff_gcd in -lavutil... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... yes
checking for perl... perl
checking for perl version greater than or equal to 5.6.0... ok
checking for perl module Sys::Syslog... ok
checking for perl module DBI... ok
checking for perl module DBD::mysql... ok
checking for perl module Getopt::Long... ok
checking for perl module Time::HiRes... ok
checking for perl module Date::Manip... ok
checking for perl module LWP::UserAgent... ok
checking for perl module Device::SerialPort... ok
checking for perl module Net::FTP... ok
checking for perl module Archive::Tar... ok
checking for perl module Archive::Zip... ok
checking for perl module Net::SMTP... ok
checking for perl module MIME::Lite... ok
checking for perl module MIME::Entity... ok
checking for perl module X10::ActiveHome... ok
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating web/Makefile
config.status: creating web/graphics/Makefile
config.status: creating scripts/Makefile
config.status: creating db/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: creating zm.conf
config.status: creating src/zm_config.h
config.status: creating web/zm_config.php
config.status: creating scripts/zm
config.status: creating db/zm_create.sql
config.status: config.h is unchanged
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Base.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Config.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm
checking for scripts/ZoneMinder/Makefile... no
Checking if your kit is complete...
Looks good
Writing Makefile for ZoneMinder
servidorwireless:/datos/temp/ZoneMinder-1.22.1# make
make all-recursive
make[1]: Entering directory `/datos/temp/ZoneMinder-1.22.1'
Making all in src
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zmc.o -MD -MP -MF ".deps/zmc.Tpo" -c -o zmc.o zmc.cpp; \
then mv -f ".deps/zmc.Tpo" ".deps/zmc.Po"; else rm -f ".deps/zmc.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm.o -MD -MP -MF ".deps/zm.Tpo" -c -o zm.o zm.cpp; \
then mv -f ".deps/zm.Tpo" ".deps/zm.Po"; else rm -f ".deps/zm.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_db.o -MD -MP -MF ".deps/zm_db.Tpo" -c -o zm_db.o zm_db.cpp; \
then mv -f ".deps/zm_db.Tpo" ".deps/zm_db.Po"; else rm -f ".deps/zm_db.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_config.o -MD -MP -MF ".deps/zm_config.Tpo" -c -o zm_config.o zm_config.cpp; \
then mv -f ".deps/zm_config.Tpo" ".deps/zm_config.Po"; else rm -f ".deps/zm_config.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_coord.o -MD -MP -MF ".deps/zm_coord.Tpo" -c -o zm_coord.o zm_coord.cpp; \
then mv -f ".deps/zm_coord.Tpo" ".deps/zm_coord.Po"; else rm -f ".deps/zm_coord.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_box.o -MD -MP -MF ".deps/zm_box.Tpo" -c -o zm_box.o zm_box.cpp; \
then mv -f ".deps/zm_box.Tpo" ".deps/zm_box.Po"; else rm -f ".deps/zm_box.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_poly.o -MD -MP -MF ".deps/zm_poly.Tpo" -c -o zm_poly.o zm_poly.cpp; \
then mv -f ".deps/zm_poly.Tpo" ".deps/zm_poly.Po"; else rm -f ".deps/zm_poly.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_image.o -MD -MP -MF ".deps/zm_image.Tpo" -c -o zm_image.o zm_image.cpp; \
then mv -f ".deps/zm_image.Tpo" ".deps/zm_image.Po"; else rm -f ".deps/zm_image.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_event.o -MD -MP -MF ".deps/zm_event.Tpo" -c -o zm_event.o zm_event.cpp; \
then mv -f ".deps/zm_event.Tpo" ".deps/zm_event.Po"; else rm -f ".deps/zm_event.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_zone.o -MD -MP -MF ".deps/zm_zone.Tpo" -c -o zm_zone.o zm_zone.cpp; \
then mv -f ".deps/zm_zone.Tpo" ".deps/zm_zone.Po"; else rm -f ".deps/zm_zone.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_camera.o -MD -MP -MF ".deps/zm_camera.Tpo" -c -o zm_camera.o zm_camera.cpp; \
then mv -f ".deps/zm_camera.Tpo" ".deps/zm_camera.Po"; else rm -f ".deps/zm_camera.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_local_camera.o -MD -MP -MF ".deps/zm_local_camera.Tpo" -c -o zm_local_camera.o zm_local_camera.cpp; \
then mv -f ".deps/zm_local_camera.Tpo" ".deps/zm_local_camera.Po"; else rm -f ".deps/zm_local_camera.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_remote_camera.o -MD -MP -MF ".deps/zm_remote_camera.Tpo" -c -o zm_remote_camera.o zm_remote_camera.cpp; \
then mv -f ".deps/zm_remote_camera.Tpo" ".deps/zm_remote_camera.Po"; else rm -f ".deps/zm_remote_camera.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_file_camera.o -MD -MP -MF ".deps/zm_file_camera.Tpo" -c -o zm_file_camera.o zm_file_camera.cpp; \
then mv -f ".deps/zm_file_camera.Tpo" ".deps/zm_file_camera.Po"; else rm -f ".deps/zm_file_camera.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_monitor.o -MD -MP -MF ".deps/zm_monitor.Tpo" -c -o zm_monitor.o zm_monitor.cpp; \
then mv -f ".deps/zm_monitor.Tpo" ".deps/zm_monitor.Po"; else rm -f ".deps/zm_monitor.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_user.o -MD -MP -MF ".deps/zm_user.Tpo" -c -o zm_user.o zm_user.cpp; \
then mv -f ".deps/zm_user.Tpo" ".deps/zm_user.Po"; else rm -f ".deps/zm_user.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_jpeg.o -MD -MP -MF ".deps/zm_jpeg.Tpo" -c -o zm_jpeg.o zm_jpeg.c; \
then mv -f ".deps/zm_jpeg.Tpo" ".deps/zm_jpeg.Po"; else rm -f ".deps/zm_jpeg.Tpo"; exit 1; fi
zm_jpeg.c: In function `jpeg_mem_src':
zm_jpeg.c:392: warning: assignment discards qualifiers from pointer target type
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_regexp.o -MD -MP -MF ".deps/zm_regexp.Tpo" -c -o zm_regexp.o zm_regexp.cpp; \
then mv -f ".deps/zm_regexp.Tpo" ".deps/zm_regexp.Po"; else rm -f ".deps/zm_regexp.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_signal.o -MD -MP -MF ".deps/zm_signal.Tpo" -c -o zm_signal.o zm_signal.cpp; \
then mv -f ".deps/zm_signal.Tpo" ".deps/zm_signal.Po"; else rm -f ".deps/zm_signal.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_buffer.o -MD -MP -MF ".deps/zm_buffer.Tpo" -c -o zm_buffer.o zm_buffer.cpp; \
then mv -f ".deps/zm_buffer.Tpo" ".deps/zm_buffer.Po"; else rm -f ".deps/zm_buffer.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zm_debug.o -MD -MP -MF ".deps/zm_debug.Tpo" -c -o zm_debug.o zm_debug.c; \
then mv -f ".deps/zm_debug.Tpo" ".deps/zm_debug.Po"; else rm -f ".deps/zm_debug.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zma.o -MD -MP -MF ".deps/zma.Tpo" -c -o zma.o zma.cpp; \
then mv -f ".deps/zma.Tpo" ".deps/zma.Po"; else rm -f ".deps/zma.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zma zma.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zmu.o -MD -MP -MF ".deps/zmu.Tpo" -c -o zmu.o zmu.cpp; \
then mv -f ".deps/zmu.Tpo" ".deps/zmu.Po"; else rm -f ".deps/zmu.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zmu zmu.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zms.o -MD -MP -MF ".deps/zms.Tpo" -c -o zms.o zms.cpp; \
then mv -f ".deps/zms.Tpo" ".deps/zms.Po"; else rm -f ".deps/zms.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zms zms.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zmf.o -MD -MP -MF ".deps/zmf.Tpo" -c -o zmf.o zmf.cpp; \
then mv -f ".deps/zmf.Tpo" ".deps/zmf.Po"; else rm -f ".deps/zmf.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zmf zmf.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -Iyes/include -g -O2 -MT zmfix.o -MD -MP -MF ".deps/zmfix.Tpo" -c -o zmfix.o zmfix.cpp; \
then mv -f ".deps/zmfix.Tpo" ".deps/zmfix.Po"; else rm -f ".deps/zmfix.Tpo"; exit 1; fi
g++ -g -O2 -Lyes/lib64 -L/usr/lib64/mysql -o zmfix zmfix.o zm_config.o zm_regexp.o zm_debug.o zm_db.o zm.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/src'
Making all in web
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web'
Making all in graphics
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web'
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web'
Making all in scripts
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/scripts'
Making all in .
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1/scripts'
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/scripts'
Making all in ZoneMinder
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1/scripts/ZoneMinder'
cp lib/ZoneMinder/Trigger/Channel.pm blib/lib/ZoneMinder/Trigger/Channel.pm
cp lib/ZoneMinder/SharedMem.pm blib/lib/ZoneMinder/SharedMem.pm
cp lib/ZoneMinder/Trigger/Connection.pm blib/lib/ZoneMinder/Trigger/Connection.pm
cp lib/ZoneMinder/Trigger/Channel/File.pm blib/lib/ZoneMinder/Trigger/Channel/File.pm
cp lib/ZoneMinder/Database.pm blib/lib/ZoneMinder/Database.pm
cp lib/ZoneMinder/Trigger/Channel/Serial.pm blib/lib/ZoneMinder/Trigger/Channel/Serial.pm
cp lib/ZoneMinder/Trigger/Channel/Inet.pm blib/lib/ZoneMinder/Trigger/Channel/Inet.pm
cp lib/ZoneMinder/Trigger/Connection/Example.pm blib/lib/ZoneMinder/Trigger/Connection/Example.pm
cp lib/ZoneMinder/Trigger/Channel/Spawning.pm blib/lib/ZoneMinder/Trigger/Channel/Spawning.pm
cp lib/ZoneMinder.pm blib/lib/ZoneMinder.pm
cp lib/ZoneMinder/Config.pm blib/lib/ZoneMinder/Config.pm
cp lib/ZoneMinder/Trigger/Channel/Handle.pm blib/lib/ZoneMinder/Trigger/Channel/Handle.pm
cp lib/ZoneMinder/Trigger/Channel/Unix.pm blib/lib/ZoneMinder/Trigger/Channel/Unix.pm
cp lib/ZoneMinder/Base.pm blib/lib/ZoneMinder/Base.pm
cp lib/ZoneMinder/Debug.pm blib/lib/ZoneMinder/Debug.pm
cp lib/ZoneMinder/ConfigAdmin.pm blib/lib/ZoneMinder/ConfigAdmin.pm
Manifying blib/man3/ZoneMinder::Trigger::Channel.3pm
Manifying blib/man3/ZoneMinder::Trigger::Connection.3pm
Manifying blib/man3/ZoneMinder::SharedMem.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::File.3pm
Manifying blib/man3/ZoneMinder::Database.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::Serial.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::Inet.3pm
Manifying blib/man3/ZoneMinder.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::Spawning.3pm
Manifying blib/man3/ZoneMinder::Trigger::Connection::Example.3pm
Manifying blib/man3/ZoneMinder::Config.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::Handle.3pm
Manifying blib/man3/ZoneMinder::Base.3pm
Manifying blib/man3/ZoneMinder::Trigger::Channel::Unix.3pm
Manifying blib/man3/ZoneMinder::Debug.3pm
Manifying blib/man3/ZoneMinder::ConfigAdmin.3pm
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/scripts/ZoneMinder'
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/scripts'
Making all in db
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/db'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/db'
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1'
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1'
make[1]: Leaving directory `/datos/temp/ZoneMinder-1.22.1'
servidorwireless:/datos/temp/ZoneMinder-1.22.1# echo $?
0
servidorwireless:/datos/temp/ZoneMinder-1.22.1# ps -fe | grep zm
root 383 28937 0 15:25 pts/0 00:00:00 grep zm
servidorwireless:/datos/temp/ZoneMinder-1.22.1# make install
Making install in src
make[1]: Entering directory `/datos/temp/ZoneMinder-1.22.1/src'
test -z "/usr/local/bin" || mkdir -p -- "/usr/local/bin"
/usr/bin/install -c 'zmc' '/usr/local/bin/zmc'
/usr/bin/install -c 'zma' '/usr/local/bin/zma'
/usr/bin/install -c 'zmu' '/usr/local/bin/zmu'
/usr/bin/install -c 'zms' '/usr/local/bin/zms'
/usr/bin/install -c 'zmf' '/usr/local/bin/zmf'
/usr/bin/install -c 'zmfix' '/usr/local/bin/zmfix'
make install-exec-hook
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1/src'
( cd /usr/local/bin; mkdir -p /datos/discodatos/dominios/cgi-bin; mv zms /datos/discodatos/dominios/cgi-bin )
( cd /datos/discodatos/dominios/cgi-bin; chown www-data:www-data zms; ln -f zms nph-zms )
( cd /usr/local/bin; chmod u+s zmfix )
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/src'
make[2]: Nothing to be done for `install-data-am'.
make[1]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/src'
Making install in web
make[1]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web'
Making install in graphics
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
make[3]: Nothing to be done for `install-exec-am'.
test -z "/datos/discodatos/dominios/www/zm/graphics" || mkdir -p -- "/datos/discodatos/dominios/www/zm/graphics"
/usr/bin/install -c -m 644 'arrow-d.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-d.gif'
/usr/bin/install -c -m 644 'arrow-dl.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-dl.gif'
/usr/bin/install -c -m 644 'arrow-dr.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-dr.gif'
/usr/bin/install -c -m 644 'arrow-l.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-l.gif'
/usr/bin/install -c -m 644 'arrow-r.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-r.gif'
/usr/bin/install -c -m 644 'arrow-u.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-u.gif'
/usr/bin/install -c -m 644 'arrow-ul.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-ul.gif'
/usr/bin/install -c -m 644 'arrow-ur.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-ur.gif'
/usr/bin/install -c -m 644 'arrow-l-u.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-l-u.gif'
/usr/bin/install -c -m 644 'arrow-l-d.gif' '/datos/discodatos/dominios/www/zm/graphics/arrow-l-d.gif'
/usr/bin/install -c -m 644 'center.gif' '/datos/discodatos/dominios/www/zm/graphics/center.gif'
/usr/bin/install -c -m 644 'seq-u.gif' '/datos/discodatos/dominios/www/zm/graphics/seq-u.gif'
/usr/bin/install -c -m 644 'seq-d.gif' '/datos/discodatos/dominios/www/zm/graphics/seq-d.gif'
/usr/bin/install -c -m 644 'point-g.gif' '/datos/discodatos/dominios/www/zm/graphics/point-g.gif'
/usr/bin/install -c -m 644 'point-o.gif' '/datos/discodatos/dominios/www/zm/graphics/point-o.gif'
/usr/bin/install -c -m 644 'point-r.gif' '/datos/discodatos/dominios/www/zm/graphics/point-r.gif'
/usr/bin/install -c -m 644 'spacer.gif' '/datos/discodatos/dominios/www/zm/graphics/spacer.gif'
make install-data-hook
make[4]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
( cd /datos/discodatos/dominios/www/zm/graphics; chown www-data:www-data arrow-d.gif arrow-dl.gif arrow-dr.gif arrow-l.gif arrow-r.gif arrow-u.gif arrow-ul.gif arrow-ur.gif arrow-l-u.gif arrow-l-d.gif center.gif seq-u.gif seq-d.gif point-g.gif point-o.gif point-r.gif spacer.gif )
make[4]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web/graphics'
test -z "/datos/discodatos/dominios/www/zm" || mkdir -p -- "/datos/discodatos/dominios/www/zm"
/usr/bin/install -c -m 644 'favicon.ico' '/datos/discodatos/dominios/www/zm/favicon.ico'
/usr/bin/install -c -m 644 'zm.php' '/datos/discodatos/dominios/www/zm/zm.php'
/usr/bin/install -c -m 644 'zm_actions.php' '/datos/discodatos/dominios/www/zm/zm_actions.php'
/usr/bin/install -c -m 644 'zm_config.php' '/datos/discodatos/dominios/www/zm/zm_config.php'
/usr/bin/install -c -m 644 'zm_control_funcs.php' '/datos/discodatos/dominios/www/zm/zm_control_funcs.php'
/usr/bin/install -c -m 644 'zm_db.php' '/datos/discodatos/dominios/www/zm/zm_db.php'
/usr/bin/install -c -m 644 'zm_export_funcs.php' '/datos/discodatos/dominios/www/zm/zm_export_funcs.php'
/usr/bin/install -c -m 644 'zm_funcs.php' '/datos/discodatos/dominios/www/zm/zm_funcs.php'
/usr/bin/install -c -m 644 'zm_html.php' '/datos/discodatos/dominios/www/zm/zm_html.php'
/usr/bin/install -c -m 644 'zm_html_styles.css' '/datos/discodatos/dominios/www/zm/zm_html_styles.css'
/usr/bin/install -c -m 644 'zm_html_view_bandwidth.php' '/datos/discodatos/dominios/www/zm/zm_html_view_bandwidth.php'
/usr/bin/install -c -m 644 'zm_html_view_blank.php' '/datos/discodatos/dominios/www/zm/zm_html_view_blank.php'
/usr/bin/install -c -m 644 'zm_html_view_console.php' '/datos/discodatos/dominios/www/zm/zm_html_view_console.php'
/usr/bin/install -c -m 644 'zm_html_view_control.php' '/datos/discodatos/dominios/www/zm/zm_html_view_control.php'
/usr/bin/install -c -m 644 'zm_html_view_controlcaps.php' '/datos/discodatos/dominios/www/zm/zm_html_view_controlcaps.php'
/usr/bin/install -c -m 644 'zm_html_view_controlmenu.php' '/datos/discodatos/dominios/www/zm/zm_html_view_controlmenu.php'
/usr/bin/install -c -m 644 'zm_html_view_controlpanel.php' '/datos/discodatos/dominios/www/zm/zm_html_view_controlpanel.php'
/usr/bin/install -c -m 644 'zm_html_view_controlpreset.php' '/datos/discodatos/dominios/www/zm/zm_html_view_controlpreset.php'
/usr/bin/install -c -m 644 'zm_html_view_controlcap.php' '/datos/discodatos/dominios/www/zm/zm_html_view_controlcap.php'
/usr/bin/install -c -m 644 'zm_html_view_cycle.php' '/datos/discodatos/dominios/www/zm/zm_html_view_cycle.php'
/usr/bin/install -c -m 644 'zm_html_view_donate.php' '/datos/discodatos/dominios/www/zm/zm_html_view_donate.php'
/usr/bin/install -c -m 644 'zm_html_view_error.php' '/datos/discodatos/dominios/www/zm/zm_html_view_error.php'
/usr/bin/install -c -m 644 'zm_html_view_event.php' '/datos/discodatos/dominios/www/zm/zm_html_view_event.php'
/usr/bin/install -c -m 644 'zm_html_view_eventdetail.php' '/datos/discodatos/dominios/www/zm/zm_html_view_eventdetail.php'
/usr/bin/install -c -m 644 'zm_html_view_events.php' '/datos/discodatos/dominios/www/zm/zm_html_view_events.php'
/usr/bin/install -c -m 644 'zm_html_view_export.php' '/datos/discodatos/dominios/www/zm/zm_html_view_export.php'
/usr/bin/install -c -m 644 'zm_html_view_filter.php' '/datos/discodatos/dominios/www/zm/zm_html_view_filter.php'
/usr/bin/install -c -m 644 'zm_html_view_filtersave.php' '/datos/discodatos/dominios/www/zm/zm_html_view_filtersave.php'
/usr/bin/install -c -m 644 'zm_html_view_frame.php' '/datos/discodatos/dominios/www/zm/zm_html_view_frame.php'
/usr/bin/install -c -m 644 'zm_html_view_frames.php' '/datos/discodatos/dominios/www/zm/zm_html_view_frames.php'
/usr/bin/install -c -m 644 'zm_html_view_function.php' '/datos/discodatos/dominios/www/zm/zm_html_view_function.php'
/usr/bin/install -c -m 644 'zm_html_view_login.php' '/datos/discodatos/dominios/www/zm/zm_html_view_login.php'
/usr/bin/install -c -m 644 'zm_html_view_group.php' '/datos/discodatos/dominios/www/zm/zm_html_view_group.php'
/usr/bin/install -c -m 644 'zm_html_view_groups.php' '/datos/discodatos/dominios/www/zm/zm_html_view_groups.php'
/usr/bin/install -c -m 644 'zm_html_view_logout.php' '/datos/discodatos/dominios/www/zm/zm_html_view_logout.php'
/usr/bin/install -c -m 644 'zm_html_view_monitor.php' '/datos/discodatos/dominios/www/zm/zm_html_view_monitor.php'
/usr/bin/install -c -m 644 'zm_html_view_monitorpreset.php' '/datos/discodatos/dominios/www/zm/zm_html_view_monitorpreset.php'
/usr/bin/install -c -m 644 'zm_html_view_monitorselect.php' '/datos/discodatos/dominios/www/zm/zm_html_view_monitorselect.php'
/usr/bin/install -c -m 644 'zm_html_view_montagefeed.php' '/datos/discodatos/dominios/www/zm/zm_html_view_montagefeed.php'
/usr/bin/install -c -m 644 'zm_html_view_montageframe.php' '/datos/discodatos/dominios/www/zm/zm_html_view_montageframe.php'
/usr/bin/install -c -m 644 'zm_html_view_montagemenu.php' '/datos/discodatos/dominios/www/zm/zm_html_view_montagemenu.php'
/usr/bin/install -c -m 644 'zm_html_view_montage.php' '/datos/discodatos/dominios/www/zm/zm_html_view_montage.php'
/usr/bin/install -c -m 644 'zm_html_view_montagestatus.php' '/datos/discodatos/dominios/www/zm/zm_html_view_montagestatus.php'
/usr/bin/install -c -m 644 'zm_html_view_none.php' '/datos/discodatos/dominios/www/zm/zm_html_view_none.php'
/usr/bin/install -c -m 644 'zm_html_view_optionhelp.php' '/datos/discodatos/dominios/www/zm/zm_html_view_optionhelp.php'
/usr/bin/install -c -m 644 'zm_html_view_options.php' '/datos/discodatos/dominios/www/zm/zm_html_view_options.php'
/usr/bin/install -c -m 644 'zm_html_view_postlogin.php' '/datos/discodatos/dominios/www/zm/zm_html_view_postlogin.php'
/usr/bin/install -c -m 644 'zm_html_view_settings.php' '/datos/discodatos/dominios/www/zm/zm_html_view_settings.php'
/usr/bin/install -c -m 644 'zm_html_view_siren.php' '/datos/discodatos/dominios/www/zm/zm_html_view_siren.php'
/usr/bin/install -c -m 644 'zm_html_view_state.php' '/datos/discodatos/dominios/www/zm/zm_html_view_state.php'
/usr/bin/install -c -m 644 'zm_html_view_stats.php' '/datos/discodatos/dominios/www/zm/zm_html_view_stats.php'
/usr/bin/install -c -m 644 'zm_html_view_timeline.php' '/datos/discodatos/dominios/www/zm/zm_html_view_timeline.php'
/usr/bin/install -c -m 644 'zm_html_view_user.php' '/datos/discodatos/dominios/www/zm/zm_html_view_user.php'
/usr/bin/install -c -m 644 'zm_html_view_version.php' '/datos/discodatos/dominios/www/zm/zm_html_view_version.php'
/usr/bin/install -c -m 644 'zm_html_view_video.php' '/datos/discodatos/dominios/www/zm/zm_html_view_video.php'
/usr/bin/install -c -m 644 'zm_html_view_watchevents.php' '/datos/discodatos/dominios/www/zm/zm_html_view_watchevents.php'
/usr/bin/install -c -m 644 'zm_html_view_watchfeed.php' '/datos/discodatos/dominios/www/zm/zm_html_view_watchfeed.php'
/usr/bin/install -c -m 644 'zm_html_view_watchmenu.php' '/datos/discodatos/dominios/www/zm/zm_html_view_watchmenu.php'
/usr/bin/install -c -m 644 'zm_html_view_watch.php' '/datos/discodatos/dominios/www/zm/zm_html_view_watch.php'
/usr/bin/install -c -m 644 'zm_html_view_watchstatus.php' '/datos/discodatos/dominios/www/zm/zm_html_view_watchstatus.php'
/usr/bin/install -c -m 644 'zm_html_view_zone.php' '/datos/discodatos/dominios/www/zm/zm_html_view_zone.php'
/usr/bin/install -c -m 644 'zm_html_view_zones.php' '/datos/discodatos/dominios/www/zm/zm_html_view_zones.php'
/usr/bin/install -c -m 644 'zm_xhtml.php' '/datos/discodatos/dominios/www/zm/zm_xhtml.php'
/usr/bin/install -c -m 644 'zm_xhtml_styles.css' '/datos/discodatos/dominios/www/zm/zm_xhtml_styles.css'
/usr/bin/install -c -m 644 'zm_xhtml_view_console.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_console.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_error.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_error.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_eventdetails.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_eventdetails.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_event.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_event.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_events.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_events.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_filter.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_filter.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_frame.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_frame.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_function.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_function.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_login.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_login.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_montage.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_montage.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_state.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_state.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_video.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_video.php'
/usr/bin/install -c -m 644 'zm_xhtml_view_watch.php' '/datos/discodatos/dominios/www/zm/zm_xhtml_view_watch.php'
/usr/bin/install -c -m 644 'zm_wml.php' '/datos/discodatos/dominios/www/zm/zm_wml.php'
/usr/bin/install -c -m 644 'zm_wml_view_login.php' '/datos/discodatos/dominios/www/zm/zm_wml_view_login.php'
/usr/bin/install -c -m 644 'zm_wml_view_postlogin.php' '/datos/discodatos/dominios/www/zm/zm_wml_view_postlogin.php'
/usr/bin/install -c -m 644 'zm_wml_view_console.php' '/datos/discodatos/dominios/www/zm/zm_wml_view_console.php'
/usr/bin/install -c -m 644 'zm_wml_view_feed.php' '/datos/discodatos/dominios/www/zm/zm_wml_view_feed.php'
/usr/bin/install -c -m 644 'zm_wml_view_error.php' '/datos/discodatos/dominios/www/zm/zm_wml_view_error.php'
/usr/bin/install -c -m 644 'zm_lang.php' '/datos/discodatos/dominios/www/zm/zm_lang.php'
/usr/bin/install -c -m 644 'zm_lang_de_de.php' '/datos/discodatos/dominios/www/zm/zm_lang_de_de.php'
/usr/bin/install -c -m 644 'zm_lang_en_gb.php' '/datos/discodatos/dominios/www/zm/zm_lang_en_gb.php'
/usr/bin/install -c -m 644 'zm_lang_en_us.php' '/datos/discodatos/dominios/www/zm/zm_lang_en_us.php'
/usr/bin/install -c -m 644 'zm_lang_fr_fr.php' '/datos/discodatos/dominios/www/zm/zm_lang_fr_fr.php'
/usr/bin/install -c -m 644 'zm_lang_ja_jp.php' '/datos/discodatos/dominios/www/zm/zm_lang_ja_jp.php'
/usr/bin/install -c -m 644 'zm_lang_pl_pl.php' '/datos/discodatos/dominios/www/zm/zm_lang_pl_pl.php'
/usr/bin/install -c -m 644 'zm_lang_ru_ru.php' '/datos/discodatos/dominios/www/zm/zm_lang_ru_ru.php'
/usr/bin/install -c -m 644 'zm_lang_nl_nl.php' '/datos/discodatos/dominios/www/zm/zm_lang_nl_nl.php'
/usr/bin/install -c -m 644 'zm_lang_it_it.php' '/datos/discodatos/dominios/www/zm/zm_lang_it_it.php'
/usr/bin/install -c -m 644 'zm_lang_es_ar.php' '/datos/discodatos/dominios/www/zm/zm_lang_es_ar.php'
/usr/bin/install -c -m 644 'zm_lang_pt_br.php' '/datos/discodatos/dominios/www/zm/zm_lang_pt_br.php'
/usr/bin/install -c -m 644 'zm_lang_dk_dk.php' '/datos/discodatos/dominios/www/zm/zm_lang_dk_dk.php'
/usr/bin/install -c -m 644 'zm_lang_cs_cz.php' '/datos/discodatos/dominios/www/zm/zm_lang_cs_cz.php'
make[4]: Entering directory `/datos/temp/ZoneMinder-1.22.1/web'
( cd /datos/discodatos/dominios/www/zm; chown www-data:www-data favicon.ico zm.php zm_actions.php zm_config.php zm_control_funcs.php zm_db.php zm_export_funcs.php zm_funcs.php zm_html.php zm_html_styles.css zm_html_view_bandwidth.php zm_html_view_blank.php zm_html_view_console.php zm_html_view_control.php zm_html_view_controlcaps.php zm_html_view_controlmenu.php zm_html_view_controlpanel.php zm_html_view_controlpreset.php zm_html_view_controlcaps.php zm_html_view_controlcap.php zm_html_view_cycle.php zm_html_view_donate.php zm_html_view_error.php zm_html_view_event.php zm_html_view_eventdetail.php zm_html_view_events.php zm_html_view_export.php zm_html_view_filter.php zm_html_view_filtersave.php zm_html_view_frame.php zm_html_view_frames.php zm_html_view_function.php zm_html_view_login.php zm_html_view_group.php zm_html_view_groups.php zm_html_view_logout.php zm_html_view_monitor.php zm_html_view_monitorpreset.php zm_html_view_monitorselect.php zm_html_view_montagefeed.php zm_html_view_montageframe.php zm_html_view_montagemenu.php zm_html_view_montage.php zm_html_view_montagestatus.php zm_html_view_none.php zm_html_view_optionhelp.php zm_html_view_options.php zm_html_view_postlogin.php zm_html_view_settings.php zm_html_view_siren.php zm_html_view_state.php zm_html_view_stats.php zm_html_view_timeline.php zm_html_view_user.php zm_html_view_version.php zm_html_view_video.php zm_html_view_watchevents.php zm_html_view_watchfeed.php zm_html_view_watchmenu.php zm_html_view_watch.php zm_html_view_watchstatus.php zm_html_view_zone.php zm_html_view_zones.php zm_xhtml.php zm_xhtml_styles.css zm_xhtml_view_console.php zm_xhtml_view_error.php zm_xhtml_view_eventdetails.php zm_xhtml_view_event.php zm_xhtml_view_events.php zm_xhtml_view_filter.php zm_xhtml_view_frame.php zm_xhtml_view_function.php zm_xhtml_view_login.php zm_xhtml_view_montage.php zm_xhtml_view_state.php zm_xhtml_view_video.php zm_xhtml_view_watch.php zm_wml.php zm_wml_view_login.php zm_wml_view_postlogin.php zm_wml_view_console.php zm_wml_view_feed.php zm_wml_view_error.php zm_lang.php zm_lang_de_de.php zm_lang_en_gb.php zm_lang_en_us.php zm_lang_fr_fr.php zm_lang_ja_jp.php zm_lang_pl_pl.php zm_lang_ru_ru.php zm_lang_nl_nl.php zm_lang_it_it.php zm_lang_es_ar.php zm_lang_pt_br.php zm_lang_dk_dk.php zm_lang_cs_cz.php )
( cd /datos/discodatos/dominios/www/zm; ln -s zm.php index.php )
ln: `index.php': File exists
make[4]: [install-data-hook] Error 1 (ignored)
make[4]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web'
make[1]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/web'
Making install in scripts
make[1]: Entering directory `/datos/temp/ZoneMinder-1.22.1/scripts'
Making install in .
/usr/bin/install -c 'zmdc.pl' '/usr/local/bin/zmdc.pl'
/usr/bin/install -c 'zmaudit.pl' '/usr/local/bin/zmaudit.pl'
/usr/bin/install -c 'zmfilter.pl' '/usr/local/bin/zmfilter.pl'
/usr/bin/install -c 'zmtrigger.pl' '/usr/local/bin/zmtrigger.pl'
/usr/bin/install -c 'zmx10.pl' '/usr/local/bin/zmx10.pl'
/usr/bin/install -c 'zmwatch.pl' '/usr/local/bin/zmwatch.pl'
/usr/bin/install -c 'zmpkg.pl' '/usr/local/bin/zmpkg.pl'
/usr/bin/install -c 'zmupdate.pl' '/usr/local/bin/zmupdate.pl'
/usr/bin/install -c 'zmvideo.pl' '/usr/local/bin/zmvideo.pl'
/usr/bin/install -c 'zmcontrol-pelco-d.pl' '/usr/local/bin/zmcontrol-pelco-d.pl'
/usr/bin/install -c 'zmcontrol-pelco-p.pl' '/usr/local/bin/zmcontrol-pelco-p.pl'
/usr/bin/install -c 'zmcontrol-visca.pl' '/usr/local/bin/zmcontrol-visca.pl'
/usr/bin/install -c 'zmcontrol-panasonic-ip.pl' '/usr/local/bin/zmcontrol-panasonic-ip.pl'
/usr/bin/install -c 'zmcontrol-axis-v2.pl' '/usr/local/bin/zmcontrol-axis-v2.pl'
/usr/bin/install -c 'zmcontrol-ncs370.pl' '/usr/local/bin/zmcontrol-ncs370.pl'
/usr/bin/install -c 'zmtrack.pl' '/usr/local/bin/zmtrack.pl'
make[3]: Nothing to be done for `install-data-am'.
Making install in ZoneMinder
make[2]: Entering directory `/datos/temp/ZoneMinder-1.22.1/scripts/ZoneMinder'
Installing /usr/local/share/perl/5.8.4/ZoneMinder/SharedMem.pm
Installing /usr/local/share/perl/5.8.4/ZoneMinder/Database.pm
Installing /usr/local/share/perl/5.8.4/ZoneMinder/Config.pm
Installing /usr/local/share/perl/5.8.4/ZoneMinder/Base.pm
Installing /usr/local/share/perl/5.8.4/ZoneMinder/Debug.pm
Installing /usr/local/share/perl/5.8.4/ZoneMinder/ConfigAdmin.pm
Writing /usr/local/lib/perl/5.8.4/auto/ZoneMinder/.packlist
Appending installation info to /usr/local/lib/perl/5.8.4/perllocal.pod
make[2]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/scripts/ZoneMinder'
make[1]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/scripts'
Making install in db
make[1]: Entering directory `/datos/temp/ZoneMinder-1.22.1/db'
make[2]: Nothing to be done for `install-exec-am'.
make[1]: Leaving directory `/datos/temp/ZoneMinder-1.22.1/db'
test -z "/usr/local/etc" || mkdir -p -- "/usr/local/etc"
/usr/bin/install -c -m 644 'zm.conf' '/usr/local/etc/zm.conf'
make[3]: Entering directory `/datos/temp/ZoneMinder-1.22.1'
( cd /usr/local/etc; chown www-data:www-data zm.conf; chmod 600 zm.conf )
( if ! test -e /var/run; then mkdir /var/run; fi )
( if ! test -e /var/run/zm; then mkdir /var/run/zm; fi; chown www-data:www-data /var/run/zm; chmod u+w /var/run/zm )
make[3]: Leaving directory `/datos/temp/ZoneMinder-1.22.1'
servidorwireless:/datos/temp/ZoneMinder-1.22.1# ls
AUTHORS Makefile README README.txt confdefs.h config.status depcomp scripts zm.conf
COPYING Makefile.am README.html TODO config.h configure install-sh src zm.conf.in
ChangeLog Makefile.in README.pdf acinclude.m4 config.h.in configure.in missing stamp-h1
INSTALL NEWS README.rtf aclocal.m4 config.log db mkinstalldirs web
servidorwireless:/datos/temp/ZoneMinder-1.22.1# zmupdate.pl
servidorwireless:/datos/temp/ZoneMinder-1.22.1# cd /
servidorwireless:/# cd datos
servidorwireless:/datos# ls
discodatos script temp
servidorwireless:/datos# cd do
-su: cd: do: No such file or directory
servidorwireless:/datos# cd discodatos/
servidorwireless:/datos/discodatos# ls
cpan dominios
servidorwireless:/datos/discodatos# cd dominios/
servidorwireless:/datos/discodatos/dominios# ls
cgi-bin log temp www
servidorwireless:/datos/discodatos/dominios# cd www
servidorwireless:/datos/discodatos/dominios/www# ls
analog apache2-default ftpimg index.html phpMyAdmin-2.7.0-pl2 phpmyadmin zm
servidorwireless:/datos/discodatos/dominios/www# zmupdate.pl -version=1.22.0 --user=root --pass=**********
Update agent starting at 06/04/26 15:29:02
Initiating database upgrade to version 1.22.1
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop :
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file if you have a lot of events.
Press 'y' for a backup or 'n' to continue : n
Upgrading database to version 1.22.1
Database successfully upgraded from version 1.22.0.
Updating monitors. Please wait.
Updating mail configuration. Please wait.
Loading config from DB
No option 'ZM_NO_MAX_FPS_ON_ALARM' found, removing at /usr/local/share/perl/5.8.4/ZoneMinder/ConfigAdmin.pm line 1627, <STDIN> line 2.
Saving config to DB
Database upgrade to version 1.22.1 successful.
Update agent exiting at 06/04/26 15:30:16
I make some testing about the running.
servidorwireless:/datos/temp/ZoneMinder-1.22.1# /etc/init.d/zm start
Starting ZoneMinder: Warning, overriding installed ./zm.conf file with local copy
Can't exec "sudo": No such file or directory at /usr/local/bin/zmpkg.pl line 252.
Use of uninitialized value in scalar chomp at /usr/local/bin/zmpkg.pl line 261.
Use of uninitialized value in concatenation (.) or string at /usr/local/bin/zmpkg.pl line 262.
success
Yes I don't have sudo, but I install...
Stopping ZoneMinder: Warning, overriding installed ./zm.conf file with local copy
success
success
The server are up and running.
Looks good
make all-recursive
Making all in src
Making all in web
Making all in .
Making all in db
0
Making install in .
cpan dominios
Saving config to DB
success
success
success
