JuanW
Posts: 13 Joined: Tue Mar 07, 2006 7:18 pm
Post
by JuanW » Fri Apr 28, 2006 1:15 pm
Goodday,
what does this meen?
zmu -q -v -m 1*** glibc detected *** /usr/local/bin/zmc: malloc(): memory corruption: 0x0f61ef40 ***
i am posting my
cam settings:
[root@zoneminder ~]# zmu -q -v -m 1
Monitor 1(Cam1)
Type : Local
Device : /dev/video0
Channel : 0
Format : 0
Width : 320
Height : 240
Palette : 1
Colours : 1
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 40
Warmup Count : 25
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 10.00
Reference Blend %ge : 7
Track Motion : 0
Function: 3 - Motion Detection
Zones : 1
Label : All
Type: 1 - Active
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 0
Max Alarm Pixels : 0
Filter Box : 3,3
Min Filter Pixels : 0
Max Filter Pixels : 0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
zoneminder
Site Admin
Posts: 5215 Joined: Wed Jul 09, 2003 2:07 pm
Post
by zoneminder » Fri Apr 28, 2006 3:59 pm
I'm not sure I fully understand. Your first example shows zmu crashing, or appears to, and your second example shows it working. Can you add a little more detail to what the problem is and when you get it?
Phil
JuanW
Post
by JuanW » Sat Apr 29, 2006 5:58 pm
I have manage to fix the problem by replacing the database with a clean one and recreated the cameras. So far it is working ok. No Idea what was wrong thou. Thank you for your support.
zoneminder
Site Admin
Post
by zoneminder » Sun Apr 30, 2006 9:49 pm
Good, I'm glad you got it fixed. Let us know if you get the problem again.
Phil
