Hell Guys, i have a little probleam...
I would like to monitor my cameras throught the Zoneminder, and record the video at a VCR, what is the solution that you can give me?
How to record into ZoneMinder and VCR at the same time?
- zoneminder
- Site Admin
- Contact:
You should be able to feed the signals from your cameras through a video splitter, one path of which goes to your ZM box, and one path of which goes to to your VCR. You may well need an RF modulator on this leg so your VCR can 'tune in' to your cam signal unless it has a direct video input. If you have several cameras you will probably also want a 'quad' so you can monitor maybe four images at once.
Phil
