Missing zone preset if upgraded.
Posted: Tue May 02, 2006 2:37 pm
Hi Phil,
1.22.1 is looking great.
I found one issue if upgrading from 1.22.0 which had 5 zone presets. 1.22.1 has 6 and the 6th is not added by update sql. So 'Best, high sensitivity' is missing after upgrade.
Should take care of it.
INSERT INTO ZonePresets VALUES (6,'Best, high sensitivity','Active','Percent','Blobs',20,NULL,8,NULL,3,3,6,NULL,5,NULL,1,NULL);
