Zoneminder with external keypad or smartcard
execcr
Post by execcr »
Hi, i have a question for you. I'm interesting to make an alarm security sistem under linux and i choose zoneminder for the cctv system. Now i will connect trough a K8055 some infrared sensor, some contact sensor for door and windows and through serial port a smartcard reader. To activate/deactivate the system i would want to use a smartcard or a keypad, but it is possible to integrate that with zoneminder with a script?? For example: --> Insert smartcard and then the alarms shutoff (but zonealarm register the event). As a normal security system, that it uses a keypad in order to shutoff the system. thanks federico (sorry for bad english :oops: )
zoneminder
Site Admin
Post by zoneminder »
If you have a defined serial interface from your access control system that your ZM can interface with then this should be possible. You will have to create a connection type to use with zmtrigger.pl but this should not be particularly difficult.
Phil
execcr
Post by execcr »
thank you for the answer. there is someone that has been projected some similiar?
bkortleven
Post by bkortleven »
Hmmmm
I've been looking at this for the past few weeks too.
When you hook a simple keypad with builtin code memory, and a relay contact, you can hook ik up onto the serial port, and read out the status every x seconds... If status = X, then start service, if status = !X then stop service.
You can even set output through the same serial port.
Or even hook up a small 2 line lcd or so onto the serial port, for status etc...
I'm not a programmer, but I'm full of ideas...
So, let me know if you have anything that needs tweaking or testing...
Thanks!
jameswilson
Post by jameswilson »
from my reasearch a serial port cannot be used for direct contact monitoing, but the paralell port can.
James Wilson
