No video displayed, only shows navigation bar on left and ..
madlinux
Post by madlinux »
I am having no luck with getting any video to display, I am using the lates realease of Zoneminder 1.22.1 installed on Ubuntu HH.
When I click on the cam I see no picture diplayed only text "java.io.FileNotFoundException: http://localhost/cgi-bin/nph-zms?mode=j ... 0&maxfps=5"
Next to it when I hover over it with my mouse is the feature bar for cambozola. So I am assuming that that works, I am also getting some funky error's which I will post below.
root@THEBUN:/tmp# tail -f zmdc.log
Corrupt JPEG data: premature end of data segment
Invalid JPEG file structure: two SOI markers
05/12/06 09:45:54.085931 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:45:59.659545 zmdc[14341].INF ['zmc -m 4' started at 06/05/12 09:45:59]
05/12/06 09:45:59.678360 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:45:59, pid = 14341]
Corrupt JPEG data: 6 extraneous bytes before marker 0xdb
05/12/06 09:46:51.994584 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 255]
05/12/06 09:47:01.249788 zmdc[14449].INF ['zmc -m 4' started at 06/05/12 09:47:01]
05/12/06 09:47:01.251452 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:47:01, pid = 14449]
05/12/06 09:47:48.229640 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:47:52.365851 zmdc[14523].INF ['zmc -m 4' started at 06/05/12 09:47:52]
05/12/06 09:47:52.372512 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:47:52, pid = 14523]
05/12/06 09:48:30.987908 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:48:43.433279 zmdc[14586].INF ['zmc -m 4' started at 06/05/12 09:48:43]
05/12/06 09:48:43.438743 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:48:43, pid = 14586]
05/12/06 09:49:23.675245 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:49:34.781787 zmdc[14661].INF ['zmc -m 4' started at 06/05/12 09:49:34]
05/12/06 09:49:34.782985 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:49:34, pid = 14661]
05/12/06 09:50:13.020138 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:50:27.104967 zmdc[14728].INF ['zmc -m 4' started at 06/05/12 09:50:27]
05/12/06 09:50:27.110935 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:50:27, pid = 14728]
Unsupported marker type 0x43
05/12/06 09:51:09.111617 zmdc[11474].ERR ['zmc -m 4' exited abnormally, exit status 1]
05/12/06 09:51:18.112933 zmdc[14780].INF ['zmc -m 4' started at 06/05/12 09:51:18]
05/12/06 09:51:18.131187 zmdc[11474].INF ['zmc -m 4' starting at 06/05/12 09:51:18, pid = 14780]
root@THEBUN:~# tail -f /var/log/apache2/error.log
[Fri May 12 08:41:28 2006] [error] [client 192.168.53] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://192.168.152/zm/htdocs/index.php?view=watchfeed& mode=&mid=4&scale=100&control=
[Fri May 12 08:42:48 2006] [error] [client 192.168.53] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://192.168.152/zm/htdocs/index.php?view=watchfeed& mode=&mid=4&scale=100&control=
[Fri May 12 08:43:05 2006] [error] [client 192.168.75] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://192.168.152/zm/htdocs/index.php?view=watchfeed& mode=&mid=4&scale=100&control=
[Fri May 12 08:43:23 2006] [error] [client 192.168.53] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://192.168.152/zm/htdocs/index.php?view=watchfeed& mode=&mid=4&scale=100&control=
[Fri May 12 08:43:27 2006] [error] [client 192.168.75] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://192.168.152/zm/htdocs/index.php?view=watchfeed& mode=&mid=4&scale=100&control=
[Fri May 12 09:39:34 2006] [error] [client 127.0.0.1] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://localhost/zm/htdocs/index.php?vi ... 0&control=
[Fri May 12 09:39:45 2006] [error] [client 127.0.0.1] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://localhost/zm/htdocs/index.php?vi ... 0&control=
[Fri May 12 09:40:22 2006] [error] [client 127.0.0.1] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://localhost/zm/htdocs/index.php?vi ... 0&control=
[Fri May 12 09:44:51 2006] [error] [client 192.168.53] File does not exist: /var/www/zm/htdocs/cgi-bin, referer: http://zm.datatronics.com/index.php?vie ... 0&control=
[Fri May 12 09:46:09 2006] [error] [client 127.0.0.1] script not found or unable to stat: /usr/lib/cgi-bin/nph-zms, referer: http://localhost/zm/htdocs/index.php?vi ... 0&control=
[Fri May 12 09:46:52 2006] [error] [client 192.168.53] File does not exist: /var/www/zm/htdocs/cgi-bin, referer: http://zm.datatronics.com/index.php?vie ... 0&control=
[/img]
madlinux
Post by madlinux »
I have the live ZM cd running on my laptop, with that I can see the images from my camera fine, still no luck with my install though.
When I record I do get events, there is just no video only stills.
madlinux
Post by madlinux »
Well now I am getting a black image when I go to view the cam, I added a AddHandler to my conf file for the zm website, I explicitly set the path to where the cgi-bin was located and that seemed to help. Still no luck though,
I didn't think that I have to use cambozola though is there another way?
