Random Ending of events
jameswilson
Post by jameswilson »
I have another box doing this now but worse than my other one. Its an axis 206m
I have a box fx60 2 gig asus mobo
1 x 206m
2 x pana blc-10's
and 3 local cams
if i turn the pana's only to mocord all is good
if i then add either the local cams or the ip cam i get fundredes of shore events (variable lengle soma as short as 0.5s)
syslog
May 15 16:38:48 localhost zma_m6[26329]: INF [Ended event]
May 15 16:38:48 localhost zma_m6[26329]: INF [MegaPixel: 1537 - Starting new event 249025]
May 15 16:39:55 localhost zma_m6[26329]: INF [Ended event]
May 15 16:39:56 localhost zma_m6[26329]: INF [MegaPixel: 1686 - Starting new event 249026]
May 15 16:39:59 localhost zma_m6[26329]: INF [Ended event]
May 15 16:39:59 localhost zma_m6[26329]: INF [MegaPixel: 1693 - Starting new event 249027]
May 15 16:40:05 localhost zma_m6[26329]: INF [Ended event]
May 15 16:40:05 localhost zma_m6[26329]: INF [MegaPixel: 1708 - Starting new event 249028]
May 15 16:42:19 localhost zma_m6[26329]: INF [MegaPixel: 2000 - Processing at 2.19 fps]
May 15 16:42:48 localhost zma_m6[26329]: INF [Ended event]
May 15 16:42:49 localhost zma_m6[26329]: INF [MegaPixel: 2063 - Starting new event 249029]
May 15 16:42:56 localhost zmc_m6[8001]: INF [MegaPixel: 430000 - Capturing at 2.19 fps]
May 15 16:43:03 localhost zma_m6[26329]: INF [Ended event]
May 15 16:43:04 localhost zma_m6[26329]: INF [MegaPixel: 2096 - Starting new event 249030]
May 15 16:43:15 localhost zma_m6[26329]: INF [Ended event]
May 15 16:43:15 localhost zma_m6[26329]: INF [MegaPixel: 2122 - Starting new event 249031]
Now all ip cams are set to jpeg mode so i can throttle the cams with zm.
I have another box that does this too but i restart it every 24 hours and it runs ok (for the moment)
I have checked the zm logs and cant see anything and in all other respects it works fine. The only thing im thinking is that both these systems are on amd x2's (4400 and an fx60) and both on via chipsets in asus mobo's.
James Wilson
zoneminder
Site Admin
Post by zoneminder »
I would like to get to the bottom of this. Is the cam in the example above doing mocord?
Phil
dsdee
Panasonic BLC's
Post by dsdee »
It may or may not be related, but make sure your setting for "Limit Continuous Motion JPEG" is set to "Unlimited" on the "Setup" Tab / Advanced / "Image Display"
if it's not set to unlimited, you should be able to correlate the times of the failures with the duration set for the time-limit.
--d2
jameswilson
thanks for the reply but it is and that i think only applies to mjpeg streams.
Its worse in mocord Phil, but the above logs are in record mode
If needed i can get you full access to this as its the one on our offices!!!
James Wilson
zoneminder
Site Admin
Are you running 1.22.1? If so what are the event causes?
Phil
jameswilson
no its on 1.22.0 at the mo (so is the other one)
James Wilson
jameswilson
 24 23:08:59 localhost zma_m5[3072]: INF [Cam_4: 142502 - Left alarm state (4038837) - 480(186) images]
May 24 23:09:00 localhost zmdc[2922]: INF [Starting pending process, zmc -m 22]
May 24 23:09:00 localhost zmdc[2922]: INF ['zmc -m 22' starting at 06/05/24 23:09:00, pid = 13439]
May 24 23:09:00 localhost zmdc[13439]: INF ['zmc -m 22' started at 06/05/24 23:09:00]
May 24 23:09:00 localhost zmc_m22[13439]: INF [Debug Level = 0, Debug Log = <none>]
May 24 23:09:00 localhost zmc_m22[13439]: INF [Starting Capture]
May 24 23:09:00 localhost zma_m2[3044]: INF [Cam_1: 143912 - Gone into alarm state]
May 24 23:09:01 localhost zma_m2[3044]: INF [Cam_1: 143913 - Gone into alert state]
May 24 23:09:01 localhost zma_m2[3044]: INF [Cam_1: 143915 - Left alarm state (4038847) - 528(205) images]
May 24 23:09:03 localhost zma_m5[3072]: INF [Cam_4: 142509 - Gone into alarm state]
May 24 23:09:03 localhost zma_m2[3044]: INF [Cam_1: 143918 - Gone into alarm state]
May 24 23:09:03 localhost zmc_m22[13439]: ERR [Can't connect to remote camera: No route to host]
May 24 23:09:03 localhost zmdc[2922]: ERR ['zmc -m 22' crashed, exit status 255]
May 24 23:09:03 localhost zma_m5[3072]: INF [Cam_4: 142511 - Gone into alert state]
May 24 23:09:04 localhost zma_m2[3044]: INF [Cam_1: 143921 - Gone into alert state]
May 24 23:09:04 localhost zma_m5[3072]: INF [Cam_4: 142513 - Left alarm state (4038837) - 485(188) images]
May 24 23:09:05 localhost zma_m2[3044]: INF [Cam_1: 143922 - Gone back into alarm state]
May 24 23:09:05 localhost zma_m2[3044]: INF [Cam_1: 143924 - Gone into alert state]
May 24 23:09:06 localhost zma_m2[3044]: INF [Cam_1: 143925 - Gone back into alarm state]
May 24 23:09:06 localhost zmc_m19[3256]: INF [Cam_18: 132000 - Capturing at 1.97 fps]
May 24 23:09:06 localhost zma_m2[3044]: INF [Cam_1: 143926 - Gone into alert state]
May 24 23:09:07 localhost zma_m2[3044]: INF [Cam_1: 143928 - Left alarm state (4038847) - 539(211) images]
May 24 23:09:10 localhost zma_m2[3044]: INF [Cam_1: 143935 - Gone into alarm state]
May 24 23:09:11 localhost zma_m2[3044]: INF [Cam_1: 143937 - Gone into alert state]
May 24 23:09:12 localhost zma_m2[3044]: INF [Cam_1: 143939 - Left alarm state (4038847) - 544(213) images]
May 24 23:09:18 localhost zma_m2[3044]: INF [Cam_1: 143952 - Gone into alarm state]
May 24 23:09:19 localhost zma_m2[3044]: INF [Cam_1: 143954 - Gone into alert state]
May 24 23:09:20 localhost zma_m2[3044]: INF [Cam_1: 143956 - Left alarm state (4038847) - 551(215) images]
May 24 23:09:22 localhost zma_m10[3168]: INF [Cam_9: 137424 - Gone into alarm state]
May 24 23:09:22 localhost zma_m10[3168]: INF [Cam_9: 137425 - Gone into alert state]
May 24 23:09:23 localhost zma_m10[3168]: INF [Cam_9: 137427 - Left alarm state (4038830) - 298(28) images]
May 24 23:09:31 localhost zma_m16[3236]: INF [Cam_15: 139105 - Gone into alarm state]
May 24 23:09:32 localhost zma_m2[3044]: INF [Cam_1: 143981 - Gone into alarm state]
May 24 23:09:35 localhost zma_m2[3044]: INF [Cam_1: 143988 - Gone into alert state]
May 24 23:09:35 localhost zmc_dvideo0[3039]: INF [Cam_2: 151000 - Capturing at 2.19 fps]
May 24 23:09:36 localhost zma_m2[3044]: INF [Cam_1: 143990 - Left alarm state (4038847) - 565(222) images]
May 24 23:09:36 localhost zma_m14[3220]: INF [Cam_13: 137000 - Processing at 2.14 fps]
May 24 23:09:38 localhost zma_m2[3044]: INF [Cam_1: 143994 - Gone into alarm state]
May 24 23:09:38 localhost zma_m5[3072]: INF [Cam_4: 142587 - Gone into alarm state]
May 24 23:09:39 localhost zma_m2[3044]: INF [Cam_1: 143997 - Gone into alert state]
May 24 23:09:39 localhost zma_m6[3082]: INF [Cam_5: 137000 - Processing at 2.16 fps]
May 24 23:09:41 localhost zma_m13[3194]: INF [Cam_12: 138213 - Gone into alarm state]
May 24 23:09:47 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:47 localhost zma_m10[3168]: INF [Cam_9: 137480 - Gone into alarm state]
May 24 23:09:47 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:48 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:48 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:50 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:50 localhost zmc_dvideo0[3039]: INF [Cam_4: 151000 - Capturing at 2.17 fps]
May 24 23:09:52 localhost zma_m6[3082]: INF [Cam_5: 137027 - Gone into alarm state]
May 24 23:09:55 localhost zma_m12[3186]: INF [Cam_11: 138000 - Processing at 2.15 fps]
May 24 23:09:55 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:56 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:56 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:56 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:57 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:09:58 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:00 localhost zma_m20[3271]: INF [Ended event]
May 24 23:10:00 localhost zma_m9[3158]: INF [Ended event]
May 24 23:10:00 localhost zma_m21[3297]: INF [Ended event]
May 24 23:10:00 localhost zma_m19[3261]: INF [Ended event]
May 24 23:10:00 localhost zma_m7[3118]: INF [Ended event]
May 24 23:10:00 localhost zma_m4[3064]: INF [Ended event]
May 24 23:10:00 localhost zma_m11[3178]: INF [Ended event]
May 24 23:10:00 localhost zma_m15[3228]: INF [Ended event]
May 24 23:10:00 localhost zma_m3[3056]: INF [Ended event]
May 24 23:10:00 localhost zma_m24[3341]: INF [Ended event]
May 24 23:10:00 localhost zma_m8[3128]: INF [Ended event]
May 24 23:10:00 localhost zma_m18[3251]: INF [Ended event]
May 24 23:10:00 localhost zma_m23[3331]: INF [Ended event]
May 24 23:10:00 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:00 localhost zma_m12[3186]: INF [Ended event]
May 24 23:10:00 localhost CROND[14223]: (root) CMD (nice -n 19 run-parts /etc/cron.hourly)
May 24 23:10:05 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:05 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:05 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:06 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:06 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:08 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:09 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:14 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:14 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:15 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:15 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:15 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:17 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:17 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:17 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:17 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:18 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:19 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:19 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:20 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:20 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:20 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:20 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:23 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:24 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:24 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:24 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:24 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:26 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:27 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:27 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:27 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:27 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:30 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:29 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:29 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:30 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:30 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:30 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:32 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:33 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:33 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:33 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:33 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:35 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:35 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:35 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:36 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:37 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:39 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:40 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:40 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:40 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:40 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:40 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:41 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:42 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:42 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:42 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:42 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:43 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:44 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:44 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:45 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:45 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:45 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:45 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:45 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:46 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:46 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:49 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:50 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:50 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:50 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:50 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:50 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:51 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:51 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:51 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:51 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:52 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:53 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:53 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:53 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:54 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:54 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:54 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:54 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:54 localhost zmc_dvideo0[3039]: INF [Cam_3: 151000 - Capturing at 2.19 fps]
May 24 23:10:54 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:55 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:10:56 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:00 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:01 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:01 localhost zmc_dvideo1[3077]: INF [Cam_7: 146000 - Capturing at 2.16 fps]
May 24 23:11:02 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:02 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:02 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:02 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:02 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:03 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:03 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:03 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:04 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:05 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:05 localhost zmc_dvideo1[3077]: INF [Cam_6: 146000 - Capturing at 2.18 fps]
May 24 23:11:06 localhost zmc_dvideo1[3077]: INF [Cam_5: 146000 - Capturing at 2.16 fps]
May 24 23:11:09 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:09 localhost zmc_dvideo1[3077]: INF [Cam_8: 146000 - Capturing at 2.16 fps]
May 24 23:11:09 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:10 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:11 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:11 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:11 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:11 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:11 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:12 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:12 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:12 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:12 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:14 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:18 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:18 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:19 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:19 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:19 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:20 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:21 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:21 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:21 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:21 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:21 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:24 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:27 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:28 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:28 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:28 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:29 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:30 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:31 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:33 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:36 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:37 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:38 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:39 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:39 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:39 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:39 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:40 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:40 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:40 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:40 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:41 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:41 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:43 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:45 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:46 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:47 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:48 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:48 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:48 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:48 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:48 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:50 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:50 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:50 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:51 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:51 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:51 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:52 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:54 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:55 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:55 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo0[3039]: INF [Cam_1: 151000 - Capturing at 2.17 fps]
May 24 23:11:56 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:57 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:56 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:57 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:57 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:57 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:11:57 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:00 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:00 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:01 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:01 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:01 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:01 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:01 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:03 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:04 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:04 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:04 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:05 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:06 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:06 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:06 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:07 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:10 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:11 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:12 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:13 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:14 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:15 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:15 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:15 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:15 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:15 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:16 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:20 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 18, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:20 localhost zmc_m21[3278]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:21 localhost zmc_m20[3266]: WAR [Buffer overrun at index 8, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:21 localhost zmc_m23[3326]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:21 localhost zmc_m18[3246]: WAR [Buffer overrun at index 15, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:21 localhost zmc_m19[3256]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:22 localhost zmc_m24[3336]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:22 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:22 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 13, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 16, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 9, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 14, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:23 localhost zmc_dvideo0[3039]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:24 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:24 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 4, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:24 localhost zmc_dvideo1[3077]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:24 localhost zmc_dvideo2[3163]: WAR [Buffer overrun at index 6, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:24 localhost zmc_dvideo3[3215]: WAR [Buffer overrun at index 19, slow down capture, speed up analysis or increase ring buffer size]
May 24 23:12:26 localhost zmc_dvideo3[3215]: WAR [Buf
James Wilson
zoneminder
Site Admin
I can't see anything here that indicates bogus events being created. But you are getting a lot of buffer overruns which is a 'bad thing'.
Phil
jameswilson
Phil,
Im not having bogus events what happens is the event ends just like normal (ie no error) then immediatly restarts every 0.5 second to 15 secs as if it had hit section length.
The above log is from a machine that is doing it but only when its been running for about 16 hours. a restart every 24 keeps it under control. I have checked the logs and the crontab to see if anything kicks of but alas no. This system never buffer underruns but i noticed i have about 3 minutes of video missing after the end of one event and the begining of the next, but on all!! cameras (22 of them) So i checked the log and found the above. Now i need to find out why it under ran for that period but wasnt before and stopped afterwards.
This system also isnt rotating its logs for some reason. If i try to run it manually nothing happens it just pauses and logs nothing. Im wondering if they are related?
On another note i noticed one of the systems (my fx60 test rig) had issues with its keyboard ie press the a key once and get 5 a's press it again get 1 a etc etc. Kernel update (2.6.14) seemd to help but it was running on this before when i noticed the ending of events, and went back to a 2.6.13 smp kernel. I have also updated to 1.22.1 to see if that helps
James Wilson
zoneminder
Site Admin
If all cams 'seize up' at the same time I would suspect a cpu issue. Maybe something running that totally hogs all the processor so that everything else just gets bogged down.
Phil
jameswilson
Thats what i thought but i cant see anything in the logs and it was still logging loads per second and its a dual core so wouldnt it have to be 2 processes on different cores?
James Wilson
zoneminder
Site Admin
Yes, unless it was a process that was forking other processes to do the work in which case I would expect them to be shared among the processors.
Phil
jameswilson
i will keep looking for things. Anyway since u/g to 1.22.1 things seem ok but it hasnt been up too long so i will report back. Has anything changed between 22.0 to 22.1 that could be related
James Wilson
