getting the following message after installing ZM on my ubuntu system using documentation for Debian, with only reservation that i compiled the code from source, as the apt way didn't work (needs some older packages that are no longer available) :
Warning: mysql_pconnect() [function.mysql-pconnect]: Lost connection to MySQL server during query in /var/www/zm/zm_db.php on line 21
Could not connect to database: Lost connection to MySQL server during query
never dealt with mysql, can anyone give me some ideas how to go about fixing the issue?
i have not touched the zm.conf
also upon exec'ing the following here is what i get:
root@ubuntu:/usr/local/etc# mysql -u zmuser -p
Enter password: <type in "zmpass">
ERROR 1045: Access denied for user: 'zmuser@localhost' (Using password: YES)
Alex
mysql errors: HELP!
- zoneminder
- Site Admin
- Contact:
Hi
Thanks for help
I understand that it's just a hobby project, but is there a step by step documentation about how to install and configure ZM (i am not even talking about using it)
I tried to follow the debian short doc along with the "Install" section of the main doc, but ended up with non complying mysql and these errors upon "make install":
make[4]: Entering directory `/home/ababkin/security/ZoneMinder-1.22.1/web/graphics'
( cd /var/www/zm/graphics; chown apache:apache arrow-d.gif arrow-dl.gif arrow-dr.gif arrow-l.gif arrow-r.gif arrow-u.gif arrow-ul.gif arrow-ur.gif arrow-l-u.gif arrow-l-d.gif center.gif seq-u.gif seq-d.gif point-g.gif point-o.gif point-r.gif spacer.gif )
chown: `apache:apache': invalid user
make[4]: *** [install-data-hook] Error 1
make[4]: Leaving directory `/home/ababkin/security/ZoneMinder-1.22.1/web/graphics'
make[3]: *** [install-data-am] Error 2
make[3]: Leaving directory `/home/ababkin/security/ZoneMinder-1.22.1/web/graphics'
make[2]: *** [install-am] Error 2
make[2]: Leaving directory `/home/ababkin/security/ZoneMinder-1.22.1/web/graphics'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/ababkin/security/ZoneMinder-1.22.1/web'
make: *** [install-recursive] Error 1
Please help
Alex
Thanks for help
Please help
Alex
- zoneminder
- Site Admin
- Contact:
I assume you have followed the install instructions in the README?
The problem you are gettign is because you have defined your web user and group as apache in configure, however on your system this account does not appear to exist. You will probably have to use a different name, for instance wwwroot.
Phil
