Page 1 of 1
ZoneMinder Wiki
Posted: Fri May 19, 2006 1:54 pm
by zoneminder
Just in case anyone hasn't read the news or announcements, there is a new Wiki section of the site.
If you are contributing anything to ZoneMinder then please consider whether the Wiki might now be a better place to do so. This may especially be true for anything which will have any ongoing development or require updates.
If you do use the Wiki, you are of course very welcome to post here to let everyone know and/or linking to the Wiki page.
Posted: Fri May 19, 2006 9:12 pm
by maciekc
Good idea with wiki!
Thanks for that!
Posted: Fri May 19, 2006 9:29 pm
by jameswilson
Ill give it a go but
I cant seem to see where i join the wiki users group so i can log in and once on the wiki if i then try to go back to the forums i get a scripting error. Might be the fact i have all debugging turned on my browser for asp dev or jsut my old win 2k os??
James
Posted: Fri May 19, 2006 9:56 pm
by zoneminder
Just click on 'UserGroups' above. I might remove this requirement if it is a pain, it just came as the default setup.
Posted: Mon May 22, 2006 8:18 pm
by maciekc
Wiki is growing up:)
It will be a lot of better than forum, if someone wants to share wisdom with others.
I will soon add hardware section and some photos and settings of hardware which I'm using. That should be very usefull.
Posted: Wed May 24, 2006 4:27 pm
by zoneminder
I have put some hardware preliminary stuff on there.
And there is now no longer any requirement to join the Wiki group.
Posted: Wed May 24, 2006 5:20 pm
by maciekc
@Phil
Could you delete this file from wiki?
"Image:0002.jpg" (Pico2000 DVR card 1)
I uploaded it two times by a mistake.
Posted: Wed May 24, 2006 10:29 pm
by zoneminder
Can you confirm which one you want deleted? I have
# 09:04, 23 May 2006 Maciekc uploaded "Image:Pico2000 2.jpg" (Pico2000 DVR card 2)
# 09:04, 23 May 2006 Maciekc uploaded "Image:0002.jpg" (Pico2000 DVR card 1)
# 09:03, 23 May 2006 Maciekc uploaded "Image:Pico2000 1.jpg" (Pico2000 DVR card 1)
but the ones referenced in the entry seem to be the first and last ones and not the one in the middle.
Posted: Thu May 25, 2006 6:51 am
by maciekc
zoneminder wrote:Can you confirm which one you want deleted? I have
Delete the second one -
Posted: Thu May 25, 2006 3:39 pm
by zoneminder
Ok. Now done. I don't think you need to be admin to delete stuff do you though?
Posted: Thu May 25, 2006 4:41 pm
by maciekc
zoneminder wrote:Ok. Now done. I don't think you need to be admin to delete stuff do you though?
Hmm? How could I delete? I didn't see such option...
Posted: Fri May 26, 2006 2:30 pm
by zoneminder
If you select the image (or anything), a 'Delete' tab should appear like the Edit one does for text. It's possible that it won't show up unless you are an admin though but I would be surprised if that as the case.
Posted: Fri May 26, 2006 6:35 pm
by maciekc
zoneminder wrote:If you select the image (or anything), a 'Delete' tab should appear like the Edit one does for text. It's possible that it won't show up unless you are an admin though but I would be surprised if that as the case.
It doesn't show.
I have only: File Discussion Edit History Watch
Re: ZoneMinder Wiki
Posted: Wed Sep 04, 2013 8:33 pm
by TheKorn
Might want to add .pm as a valid file type. Can't upload a control script to the wiki as it is right now.
Re: ZoneMinder Wiki- Bkjaya's_Experiments
Posted: Wed Jun 02, 2021 4:32 pm
by bkjaya1952
