New Zoneminder server
Hogface
Post by Hogface »
I want to move off my current FC4 server to an IBM 342 (1RX) 2x Processor.
If I install FC4 will it autorecognize the additional processor (there are two).
And will Zoneminder be able to utilize it?
________
Janesville Assembly
jameswilson
Post by jameswilson »
if fc4 is smp then yes i suppose it will see the other processor, and yes zm will use all the processors it can
James Wilson
ma77hias
multiple processors
Post by ma77hias »
If fc4 does not recognize your multiple prozessors, you can use the linux distributions Scientific Linux or CentOs. Both are based on Redhat AS which supports multiple physical CPUs. And because they are based on Redhat you can use the rpms for redhat enterprise from the dag repository.
