I'm still playing with ZM - so forgive if this question is obvious.
Does the MODECT mode only record frames which have changed? Is it possible to have initial motion do full-framerate recording for a pre-determined amount of time (say 1 minute) on motion detection, or can you only record the changed frames themselves?
Trigger for continuous recording?
ps straight out the manualPre/Post Event Image Buffer – These options determine how many frames from before and after an event should be preserved with it. This allows you to view what happened immediately prior and subsequent to the event. A value of 10 for both of these will get you started but if you get a lot of short events and would prefer them to run together to form fewer longer ones then increase the Post Event buffer size. The pre-event buffer is a true buffer and should not really exceed half the ring buffer size. However the post-event buffer is just a count that is applied to captured frames and so can be managed more flexibly. You should also bear in mind the frame rate of the camera when choosing these values. For instance a network camera capturing at 1FPS will give you 10 seconds before and after each event if you chose 10 here. This may well be too much and pad out events more than necessary. However a fast video card may capture at 25FPS and you will want to ensure that this setting enables you to view a reasonable time frame pre and post event.
James Wilson
Zoneminder filter timing
deleted - posted in wrong thread
