I have 2 systems with this same problem, one is fresh install, other is old 1.21.3 system that was upgraded. I can mocord 1 cam out of 3 & record other 2 on 3 cam system. On the 6 cam system, I can mocord 3 out of 6 & record other 3.
On the 3 camera system, fresh install used 1.21.3 install from RPM
then upgraded to 1.22.0 using 1.07 rpm
Both systems are 1.8 Ghz Duron 512 Ram.
3 cam system had previous 1.21.3 system on 80 gig HD, got new 300 gig HD, installed FC3 w/XFS filesystem, but previous system would Mocord all 3 at 4 or 5 fps no prob
Now if I set all 3 to Mocord, they start out w/green status on cam, then 2nd cam switches to yellow status within seconds & stops recording, get zmdc.log shows
zma -crash in log right after each time it starts.
I upped the shared memory, no fix, I slowed cams down to 2 fps
still no fix. Tried different buffer setting, no fix, any ideas ?
here is what i find in zmdc.log
05/28/06 18:53:36.270016 zmdc[4949].INF ['zma -m 2' started at 06/05/28 18:53:36]
05/28/06 18:53:36.272312 zmdc[4847].INF ['zma -m 2' starting at 06/05/28 18:53:36, pid = 4949]
05/28/06 18:53:38.872340 zmdc[4847].ERR ['zma -m 2' crashed, exit status 11]
05/28/06 18:53:43.006243 zmdc[4847].INF [Starting pending process, zma -m 2]
1.22.0 upgrade, Can't Mocord all cams
- zoneminder
- Site Admin
- Contact:
plus if you have no joy changhe the state to none and create a new monitor just to ensure that all is ok
James Wilson
