Also, the zmupdate script (which the doco still says is in the build directory; it's actually in the scripts subdirectory) threw me this error:
acsi:/appl/ZoneMinder-1.22.2/scripts # perl zmupdate.pl -v 1.22.1 -u root -p terdea
Update agent starting at 06/05/30 11:26:37
Initiating database upgrade to version 1.22.2
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop :
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to zm-1.22.1.dump. This may take several minutes.
Database successfully backed up to zm-1.22.1.dump, proceeding to upgrade.
Upgrading database to version 1.22.2
Database successfully upgraded from version 1.22.1.
Loading config from DB
DBI::db=HASH(0x874a43c)->disconnect invalidates 1 active statement handle (either destroy statement handles or call finish on them before disconnecting) at /usr/lib/perl5/site_perl/5.8.1/ZoneMinder/ConfigAdmin.pm line 1649, <STDIN> line 2.
Saving config to DB
Database upgrade to version 1.22.2 successful.
Update agent exiting at 06/05/30 11:26:49
