Using the latest version of ZM and SuSE 10.0 I've already built one and following (which has changed but I can only remeber then svr to srv being changed)
I now get error on login on to localhost/zm.php
Fatal error: Call to undefined function: mysql_pconnect() in /srv/www/htdocs/zm_db.php on line 21
I'm sure it's something I've done but can't think what as the first time I used this how to...
http://www.zoneminder.com/forums/viewto ... 86&start=0
It worked fine, everything works fine in ZM, thanks for any pointers?
mysql_pconnect() setup problem
Well I don't know why this did not start this time
but I found the change I needed, so here it is if anyone else get's into this, I found I needed to enable...
In your php.ini:
[MySQL]
; Allow or prevent persistent links.
mysql.allow_persistent = On
The default is Off but I don't get why this didn't happen on my first install all very confused but least it's working now after hours of figuring LOL
In your php.ini:
[MySQL]
- zoneminder
- Site Admin
- Contact:
