Change date and time?
doakwolf
Post by doakwolf »
Hey all,
I've got a ZM setup and am trying to adjust the time (somehow it's out by about 10 mins) and when at the zm computer, I type 'help-zm' and it lists some commands, one of which is 'setup' - 'set the local timezone, keyboard type...'
however, when i type 'setup' it responds "-bash: setup: command not found"
this happens when logged on as both user and su.
P.S. I'm using putty to log into my ZM machine as it doesn't have a monitor attached to it.
Any ideas or other methods to change the time?
Cheers,
Jero aka Doak.
doakwolf
Nevermind!
Post by doakwolf »
I ended up finding this command on google which has worked :) "date --set="
Cheers,
Jero.
zoneminder
Site Admin
Post by zoneminder »
You can also usually use nptd which will keep your time correct continuously via Network Time Protocol.
Phil
