mpeg streaming delay
Posted: Fri Jun 02, 2006 8:48 pm
Boy, I'm just clogging up the forum today. Couldn't find any mention of this in my search, so probably it's a problem on my end.
Having installed and compiled ffmpeg, I can get streaming mpeg, but it seems to take up to 15 seconds for a real event (my hand waving in front of the camera) to show up on the mpeg streaming view. This is on a lan, and the standard jpeg view is instantaneous. Is this common/expected? Any way to fix it?
And to clarify my understanding of how the system works, the capture daemon is saving the event images as jpeg. The mpeg is only used to generate a stream for viewing/downloading, not for converting existing images to an mpeg file. would converting the existing jpegs to a single video file save disk space? Would it still be possible to use the functions such as the timeline if this was done?
Thanks!
Ed
Thanks!
Ed
