Hi all.
Have 2 videocard: falcon (England) 4 tv in , conexant fusion bt878A - 300$
and trust (Italy) 4 tvin, conexant fusion bt878A - 150$
I have installed 0.9.15. Falcon is working without problem, but trust don`t working. Cann`t understand why? Zmu have tested, all ok. Can we help me?
Regards,
Anatoliy
problem with videocard BT878A
- zoneminder
- Site Admin
- Contact:
Re: problem with videocard BT878A
Hi Anatoliy,
Have you checked that the trust is working with something like xawtv? It's always worth trying out new hardware with xawtv as it seems to support most things. Then when you know that the drivers etc are set up correctly try it with ZM
Hi Phil,
I have checked the trust with xawtv, but didn`t working. Have Red Hat 9.0 with kernel 2.4.20. Perhaps I must to change the kernel ( I meen V4L, drivers for BT878 ) , becouse I didn`t do nothing. And I have not installed the driver for bt878. What do you think?
But I want to use this video card, becouse the price is perfect :)
Regards,
Anatoliy.
Regards,
Anatoliy.
