not vizualizo cameras when I try access in 127.0.0.1
Well, first this is my first participation in the forum. As I am of Brazil and I do not say English I am using the translator of google. Then if the English will be bad forgives me. What it brings me here is the following problem. I have zoneminder 1,22-2 installed (but already I tested with other versions) in one debian sarge (also I tested in etch). Everything functions near-normal, is not only normal for this reason that I go to describe now: when access the images of monitoramento of the server to zoneminder everything occurs normal. But if I install a graphical environment in the server to zoneminder and try to visualize cameras in the navigator of Internet installed in the proper server to zoneminder the images do not load or delay very to load. The times load one camera and it does not load others. He has that to be making one reload until loading cameras. I believe that the problem is in the apache (use apache2) but is not certain. Aguem already passed for this? or it has an idea of as to solve.
if your issue is viewing via montage there is a setting change needed in firefox, If you can view from a remote computer fine then i doubt its an apache issue
James Wilson
- victor_diago
- Contact:
Hi everybody, i ask permission of the rest to talk in portuguese with this member !
Thanks if accepted.
Olá Ed marcos.
Seguinte rapaz, o zoneminder funciona perfeitamente no sistema local com o modo grafico instalado, só que você precisa configurar o navegador, o mais recomendado é o firefox.
acontece assim, o firefox possui algumas configurações que aparecem quando você digita about:config. nestas configurações, você precisa modificar o seguinte :
network.http.max-connections-per-server
network.http.max-persistent-connections-per-proxy
network.http.max-persistent-connections-per-server
mude tudo para 16 para ver 16 cameras ao mesmo tempo, etc.
também mude :
browser.cache.check_doc_frequency para 1 e não 3 como está por padrão.
o firefox permite somente o acesso a duas câmeras por padrão, pois estas conexões são permanentes. é só aumentar o valor como te falei, reiniciar o firefox e pronto.
Outra coisa, faça um curso de inglês, você deu sorte de alguem mais aqui ser do Brasil como eu, mas o inglês é a língua imprescindível para técnicos.
Para visualização local, existe um software que nosso amigo maciekc desenvolveu que nem de browser precisa. ele está no "user contribution"
abraço
You should learn english because its very difficult find help in other languages.
Thanks if accepted.
Olá Ed marcos.
também mude :
abraço
Olá, thanks a lot for its tip. Parametro: network.http.max-persistent-connections-per-server he was really who made the difference. Taking in account the English really it is necessary lack, but I go trying to lead with informatiques. How much to I lack of to have given it luck to have plus a Brazilian in the list descordo. He has Brazilian in all expensive place, we turn plague in the Internet, hehe. trick. How much to maciekc I did not have success with it, the images open equal TV when it loses the horizontal frequency, but my contact with zoneminder is recent still goes to spend much time with it. In more thanks a lot for the aid. I am red foot of Apucarana - Pr. But it only wanted to understand because when access for remote browser the problem did not occur, and that problem the same alone occurred in local browser?
Olá, muito obrigado pela sua dica. O parametro : network.http.max-persistent-connections-per-server foi realmente quem fez a diferença. Levando em conta o inglês realmente faz falta, mas vou tentando levar com o informatiques. Quanto ao falto de eu ter dado sorte de ter mais um brasileiro na lista descordo. Tem brasileiro em todo lugar cara, viramos praga na internet , hehe. brincadeira. Quanto ao maciekc não tive sucesso com ele, as imagens abrem igual tv quando perde a frequência horizontal, mas meu contato com o zoneminder é recente ainda vou gastar muito tempo com ele. No mais muito obrigado pela ajuda. Sou pé vermelho de Apucarana - Pr . Mas somente queria entender porque quando acesso pelo browser remoto o problema não ocorria, e que o mesmo problema só ocorria no browser local ?
- victor_diago
- Contact:
Thanks Victor!
James Wilson
