looking for a little help
Posted: Tue Jun 06, 2006 4:51 pm
Hi Everyone,
I've used zoneminder before and it worked quite well with a USB Cam now I'm trying to use it with network cams that require authentication, is this possible at all? I thought it would have been http://user:name@IP/
However that doesn't seem to work. Also the status on the main page reads stopped no matter how many times I restart the service or click on stop and change the status to start/running. I'm not sure if its because its not recieving a vid signal or if there is something else wrong.
Also I have the following error message in my /var/log/httpd/error-log
/usr/local/bin/zmu: error while loading shared libraries: libavcodec.so: cannot enable executable stack as shared object requires: Permission denied
[Tue Jun 06 12:52:48 2006] [error] [client IP] File does not exist: /var/www/html/images/PlantCam1-Zones.jpg, referer: http://IP/index.php?view=zones&mid=1
And this in the zmdc.log
6/06/2006 12:52:46.285891 zmdc[3045].INF ['zmc -m 1' starting at 06/06/06 12:52:46, pid = 3204]
06/06/2006 12:52:46.337801 zmdc[3045].ERR ['zmc -m 1' exited abnormally, exit status 255]
06/06/2006 12:52:46.338312 zmdc[3045].INF [Starting pending process, zmc -m 1]
06/06/2006 12:52:46.339890 zmdc[3206].INF ['zmc -m 1' started at 06/06/06 12:52:46]
06/06/2006 12:52:46.345906 zmdc[3045].INF ['zmc -m 1' starting at 06/06/06 12:52:46, pid = 3206]
06/06/2006 12:52:46.384532 zmdc[3045].ERR ['zmc -m 1' exited abnormally, exit status 255]
06/06/2006 12:52:51.085896 zmdc[3045].INF [Starting pending process, zmc -m 1]
06/06/2006 12:52:51.087538 zmdc[3210].INF ['zmc -m 1' started at 06/06/06 12:52:51]
06/06/2006 12:52:51.090158 zmdc[3045].INF ['zmc -m 1' starting at 06/06/06 12:52:51, pid = 3210]
06/06/2006 12:52:51.129107 zmdc[3045].ERR ['zmc -m 1' exited abnormally, exit status 255]
any help would be greatly appreciated. Please add me to msn if you know of a solution to this problem or are willing to help me troubleshoot.
Also if someone has a network cam that they'd be willing to let me connect to and test my setup it would be a great help I suspect these issues have something to do with the authentication. I'm running Axis 221's
