I can't seem to figure this one out. zmtrigger.pl just hangs regardless of the arguments on the command line.
Is it a daemon that listens for events? Or is it the interface to trigger events?
zmtrigger.pl
As far as i knew zmtrigger is a means of triggering zm from external sources, but i havnt read up it
James Wilson
- zoneminder
- Site Admin
- Contact:
Re: zmtrigger.pl
zmtrigger is designed to run as a daemon and so will both listen for external events and/or create them as a result of ZM alarms. You do have to configure your connectors for your particular requirements though. As shipped zmtrigger.pl just has a few example connectors.eddyhkim wrote:I can't seem to figure this one out. zmtrigger.pl just hangs regardless of the arguments on the command line.
Phil
