awesome work man
your rpm has made my life very easy these past couple of days with the problems i was having compiling.
I tried to install your latest rpm but I get some failed deps
rpm -Uhv ffmpeg-libpostproc-0.4.9-0.3.20051207.2.fc3.CTU.i386.rpm
error: Failed dependencies:
pkgconfig is needed by ffmpeg-libpostproc-0.4.9-0.3.20051207.2.fc3.CTU.i386
rpm -Uhv ffmpeg-0.4.9-0.3.20051207.2.fc3.CTU.i386.rpm
libfaac.so.0 is needed by ffmpeg-0.4.9-0.3.20051207.2.fc3.CTU.i386
libpostproc.so.0.0.1 is needed by ffmpeg-0.4.9-0.3.20051207.2.fc3.CTU.i386
libtheora.so.0 is needed by ffmpeg-0.4.9-0.3.20051207.2.fc3.CTU.i386
libxvidcore.so.4 is needed by ffmpeg-0.4.9-0.3.20051207.2.fc3.CTU.i386
[root@dvr ~]# rpm -Uhv zm-1.22.2-0.0.fc.root.i386.rpm
ffmpeg >= 0.4.9 is needed by zm-1.22.2-0.0.fc.root.i386
libavutil.so is needed by zm-1.22.2-0.0.fc.root.i386
perl(X10::ActiveHome) is needed by zm-1.22.2-0.0.fc.root.i386
is it possible to add the testing folder as a yum repo?
