Infrared-Capable Network Cameras?
dagummace
Post by dagummace »
Has anyone got experience or recommendations as to a network camera - preferably wireless - that supports infrared, yet meshes nicely with ZoneMinder?
A friend of mine wanted me to do a Zoneminder setup at his house, and he mentioned with some enthusiasm a bundle he had seen at Costco of a whole monitoring system which included a couple of cameras with IR LED's.
zoneminder
Site Admin
Post by zoneminder »
I don't know of any such cameras however I think _most_ cameras will benefit from an IR illumination source so you always just get an IR light and use regular cameras.
Phil
jameswilson
Post by jameswilson »
'most' mono cameras can utilise ir light but some are better than others, if your mad keen on ir response you need to look for a 1/2 chip wand check its freq resp graphs
James Wilson
deridere
insects
Post by deridere »
just to let you know that when you got cameras with built in IR you going to get a lot insects wondering in front of your lens- they are attracted from IR- and blocking you lenses this way.
when you got separate IR`s then the insects fly around and make nests on the IR lamp itself not on you lens.
jameswilson
I agree with the above but sperate emitters are usually expensive, but to be honest is the best way to go
James Wilson
