FC 4 / ZM 1.22 / 8 Monitors MoDect
/tmp/zmdc.log
DBD::mysql::st execute failed: Can't open file: 'Frames.MYI' (ernno 145) at /usr/local/bin/zmaudit.pl line 280
Every 10 seconds in my logs
+ "Can't open file: 'Frames.MYI' (ernno 145) "
When I want to watch events
I already tried the alldatabse repair.
Thank You.
Can't Open file Frames.MYI
- zoneminder
- Site Admin
- Contact:
Thank you,
did the trick.
Thank you again.
ps : I have lost all events since this error occured for the first time.
I had plenty of 0 sec events. I suppose the error blocked ZM to record new things in the DB.
myisamchk --silent --force --fast --update-state -O key_buffer=64M \
-O sort_buffer=64M -O read_buffer=1M -O write_buffer=1M \
/var/lib/mysql/*/*.MYI
Thank you again.
