Zoneminder alarm max fps and alarm state
Hi All!!
I'm newer to use Zoneminder and now i have a question...
i've Zoneminder 1.22.2 installed in a computer with 1100 MHz processor and RAM 1 Gb and configured for use 4 analogic camera connect to a Axis 2400 Video Server.
But now any time appears a strange error in /var/log/messages :
"INF [cam1: 232 - Gone into alert state]"
"INf [cam1: 233 - Gone back into alarm state]"
and
"ERR [zmc -m <n°id-cam> exited abnormally, exit status 255]"
"INF [Found open event '<n°event>']"
"INF closing"
What is this???
I've read that this error is associated with new introdoucing variable "Alarm Maximum Fps" setting for every cam...is it true??
thanks for help!!
and
"INF closing"
What is this???
thanks for help!!
More specifications about my problem ....
It follows the detailed log of the problem that I met .....
Jun 13 17:17:22 VideoSitram zmdc[19622]: INF ['zma -m 5' started at 06/06/13 17:17:22]
Jun 13 17:17:22 VideoSitram zmdc[17103]: INF ['zma -m 5' starting at 06/06/13 17:17:22, pid = 19622]
Jun 13 17:17:22 VideoSitram zma_m5[19622]: INF [Debug Level = 0, Debug Log = <none>]
Jun 13 17:17:22 VideoSitram zma_m5[19622]: INF [In mode 4/1, warming up]
Jun 13 17:17:23 VideoSitram zma_m5[19622]: INF [Got signal (Hangup), reloading]
Jun 13 17:17:29 VideoSitram zma_m5[19622]: INF [cam1: 7 - Processing at 1.00 fps]
Jun 13 17:17:34 VideoSitram zma_m5[19622]: INF [cam1: 012 - Starting new event 13]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Got signal (Floating point exception), crashing]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Signal address is (nil), from 0x8069f9d ]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma [0x8069f9d]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma(__gxx_personality_v0+0x3f8) [0x804b6f8]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x4617e4]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma(__gxx_personality_v0+0xd1) [0x804b3d1]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: INF [Backtrace complete]
Jun 13 17:17:35 VideoSitram zmdc[17103]: ERR ['zma -m 5' exited abnormally, exit status 8]
Jun 13 17:17:35 VideoSitram zmdc[17103]: INF [Starting pending process, zma -m 5]
Jun 13 17:17:35 VideoSitram zmdc[17103]: INF ['zma -m 5' starting at 06/06/13 17:17:35, pid = 19640]
Jun 13 17:17:35 VideoSitram zmdc[19640]: INF ['zma -m 5' started at 06/06/13 17:17:35]
Are you using mocord/record?
And what values do you have in max fps and alarm fps?
James Wilson
enter a value of 1 in alarm fps shouldnt make a difference. If your using record mode, can you list a few actual section length times
James Wilson
yeah, if you have a section length of 600 and record your events should be approx 600 long, if therfe not we need to look as to why, How long are your events then?
James Wilson
can you do a screen grab and post it as that is realy strange and i think i must be misunderstanding you, also you need to look your logs and see what is happening here
James Wilson
thats great but can you save it a bit bigger for me as i cant read that
James Wilson
zma gone into alarm state because zmc lost any frame in capture video???But why if i've 1 camera or 10 cameras in record mode, zmc lost frame??? Monitoring process with top utility result that machine load average start at 5.3 and go up until 10...12 and also 15 !!!
...why??
i hope that i explain well my question....
i dont like the 'r' this means they have been recovered and all is not well. Also a load of 15 is not gpood, id try making it smaller and setting all cams but one to none and set 1 cam as record and see what happen then
James Wilson
