Page 1 of 3
Zoneminder alarm max fps and alarm state
Posted: Tue Jun 13, 2006 10:18 am
by picard71
Hi All!!
I'm newer to use Zoneminder and now i have a question...
i've Zoneminder 1.22.2 installed in a computer with 1100 MHz processor and RAM 1 Gb and configured for use 4 analogic camera connect to a Axis 2400 Video Server.
But now any time appears a strange error in /var/log/messages :
"INF [cam1: 232 - Gone into alert state]"
"INf [cam1: 233 - Gone back into alarm state]"
and
"ERR [zmc -m <n°id-cam> exited abnormally, exit status 255]"
"INF [Found open event '<n°event>']"
"INF closing"
What is this???
I've read that this error is associated with new introdoucing variable "Alarm Maximum Fps" setting for every cam...is it true??
thanks for help!!
More specifications about my problem ....
Posted: Tue Jun 13, 2006 3:33 pm
by picard71
It follows the detailed log of the problem that I met .....
Jun 13 17:17:22 VideoSitram zmdc[19622]: INF ['zma -m 5' started at 06/06/13 17:17:22]
Jun 13 17:17:22 VideoSitram zmdc[17103]: INF ['zma -m 5' starting at 06/06/13 17:17:22, pid = 19622]
Jun 13 17:17:22 VideoSitram zma_m5[19622]: INF [Debug Level = 0, Debug Log = <none>]
Jun 13 17:17:22 VideoSitram zma_m5[19622]: INF [In mode 4/1, warming up]
Jun 13 17:17:23 VideoSitram zma_m5[19622]: INF [Got signal (Hangup), reloading]
Jun 13 17:17:29 VideoSitram zma_m5[19622]: INF [cam1: 7 - Processing at 1.00 fps]
Jun 13 17:17:34 VideoSitram zma_m5[19622]: INF [cam1: 012 - Starting new event 13]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Got signal (Floating point exception), crashing]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Signal address is (nil), from 0x8069f9d ]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma [0x8069f9d]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma(__gxx_personality_v0+0x3f8) [0x804b6f8]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x4617e4]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: ERR [Backtrace: /usr/local/bin/zma(__gxx_personality_v0+0xd1) [0x804b3d1]]
Jun 13 17:17:35 VideoSitram zma_m5[19622]: INF [Backtrace complete]
Jun 13 17:17:35 VideoSitram zmdc[17103]: ERR ['zma -m 5' exited abnormally, exit status 8]
Jun 13 17:17:35 VideoSitram zmdc[17103]: INF [Starting pending process, zma -m 5]
Jun 13 17:17:35 VideoSitram zmdc[17103]: INF ['zma -m 5' starting at 06/06/13 17:17:35, pid = 19640]
Jun 13 17:17:35 VideoSitram zmdc[19640]: INF ['zma -m 5' started at 06/06/13 17:17:35]
Posted: Wed Jun 14, 2006 9:54 am
by Dr_AxiA
i've meet similar error as you but i don't resolve it yet....& you?
I also look that the event of cams aren't be regular and not be equal to variable SECTION_LENGTH of cams....it's more strange thing...why???
Posted: Wed Jun 14, 2006 10:13 am
by jameswilson
Are you using mocord/record?
And what values do you have in max fps and alarm fps?
Posted: Wed Jun 14, 2006 10:19 am
by Dr_AxiA
i use:
-) mode: RECORD
-) max Fps: 1.00
-) max alarm Fps: nothing or other values
Posted: Wed Jun 14, 2006 10:53 am
by jameswilson
enter a value of 1 in alarm fps shouldnt make a difference. If your using record mode, can you list a few actual section length times
Posted: Wed Jun 14, 2006 12:01 pm
by Dr_AxiA
Section Length is 600....
but...you would a part of event list??
Posted: Wed Jun 14, 2006 12:30 pm
by jameswilson
yeah, if you have a section length of 600 and record your events should be approx 600 long, if therfe not we need to look as to why, How long are your events then?
Posted: Wed Jun 14, 2006 12:50 pm
by Dr_AxiA
the event length is more variable....any event's length is -1, other event's length is more large of 600 and so much...it seems that create event alternate length -1 and more of 600....
Posted: Wed Jun 14, 2006 1:07 pm
by jameswilson
can you do a screen grab and post it as that is realy strange and i think i must be misunderstanding you, also you need to look your logs and see what is happening here
Posted: Wed Jun 14, 2006 1:31 pm
by Dr_AxiA
sorry, but my english is so bad....so:
well now??
i hope that admin forum not ban me for this...
Posted: Wed Jun 14, 2006 1:40 pm
by jameswilson
thats great but can you save it a bit bigger for me as i cant read that
Posted: Thu Jun 15, 2006 8:36 am
by Dr_AxiA
zma gone into alarm state because zmc lost any frame in capture video???But why if i've 1 camera or 10 cameras in record mode, zmc lost frame??? Monitoring process with top utility result that machine load average start at 5.3 and go up until 10...12 and also 15 !!!
...why??
i hope that i explain well my question....
Posted: Thu Jun 15, 2006 9:24 am
by jameswilson
i dont like the 'r' this means they have been recovered and all is not well. Also a load of 15 is not gpood, id try making it smaller and setting all cams but one to none and set 1 cam as record and see what happen then
Posted: Thu Jun 15, 2006 9:53 am
by Dr_AxiA
now with 10 cameras have a load average of 8.5....now i set only 1 camera to record and other to none...i say you between little
