http://www.jasonh.vispa.com/Card_Front.jpg
I bought it off ebay so I am not sure of the model name, except it uses bttv 102
So it works in tvtime! so bttv and the card is setup ..But i get just the broken image square in zm.. heres my logs:
First I tried with gentoo and just ACCEPT_KEYWORDS="~x86" emerge zoneminder
I am using ZM 1.22.0 here since that is what is in portage
$ tail /tmp/zm*.log
==> /tmp/zmaudit.log <==
06/19/06 21:47:45.646244 zmaudit[26612].DBG [Found database monitor '2']
06/19/06 21:47:45.646881 zmaudit[26612].DBG [Got 0 events]
06/19/06 22:25:22.298128 zmaudit[11124].DBG [Found database monitor '1']
06/19/06 22:25:22.306682 zmaudit[11124].DBG [Got 0 events]
06/19/06 22:25:22.306969 zmaudit[11124].DBG [Found database monitor '2']
06/19/06 22:25:22.307588 zmaudit[11124].DBG [Got 0 events]
06/19/06 22:40:22.383989 zmaudit[11124].DBG [Found database monitor '1']
06/19/06 22:40:22.385269 zmaudit[11124].DBG [Got 0 events]
06/19/06 22:40:22.385550 zmaudit[11124].DBG [Found database monitor '2']
06/19/06 22:40:22.397339 zmaudit[11124].DBG [Got 0 events]
==> /tmp/zmdc.log <==
06/19/06 22:45:54.571763 zmdc[11086].ERR ['zmc -d /dev/video1' crashed, exit sta
tus 255]
06/19/06 22:45:54.934967 zmdc[12759].INF ['zmc -d /dev/video0' started at 06/06/
19 22:45:54]
06/19/06 22:45:54.942356 zmdc[11086].INF ['zmc -d /dev/video0' starting at 06/06
/19 22:45:54, pid = 12759]
06/19/06 22:45:54.987759 zmdc[11086].ERR ['zmc -d /dev/video0' crashed, exit sta
tus 255]
06/19/06 22:46:01.086389 zmdc[11086].INF [Starting pending process, zmupdate.pl
-c]
06/19/06 22:46:01.089747 zmdc[12761].INF ['zmupdate.pl -c' started at 06/06/19 2
2:46:01]
06/19/06 22:46:01.090837 zmdc[11086].INF ['zmupdate.pl -c' starting at 06/06/19
22:46:01, pid = 12761]
Bareword "ZM_PATH_BUILD" not allowed while "strict subs" in use at /usr/bin/zmup
date.pl line 311.
BEGIN not safe after errors--compilation aborted at /usr/bin/zmupdate.pl line 51
3.
06/19/06 22:46:01.607126 zmdc[11086].ERR ['zmupdate.pl -c' crashed, exit status
9]
==> /tmp/zmfilter.log <==
06/18/06 12:30:37.237981 zmfilter[9374].INF [Scanning for events]
06/18/06 12:43:38.226188 zmfilter[11067].INF [Scanning for events]
06/19/06 20:18:48.119006 zmfilter[20621].INF [Scanning for events]
06/19/06 20:40:33.311003 zmfilter[21658].INF [Scanning for events]
06/19/06 21:32:44.986207 zmfilter[26607].INF [Scanning for events]
06/19/06 22:25:21.867259 zmfilter[11119].INF [Scanning for events]
==> /tmp/zmpkg.log <==
06/19/06 20:18:42.687636 zmpkg[20579].INF [Command: start]
06/19/06 20:36:46.143869 zmpkg[21398].INF [Command: stop]
06/19/06 20:40:27.498047 zmpkg[21612].INF [Command: start]
06/19/06 21:32:20.412358 zmpkg[26520].INF [Command: stop]
06/19/06 21:32:39.014107 zmpkg[26562].INF [Command: start]
06/19/06 22:15:59.210985 zmpkg[9536].INF [Command: start]
06/19/06 22:15:59.515457 zmpkg[9536].ERR [Unable to find valid 'su' syntax]
06/19/06 22:23:18.115296 zmpkg[9589].INF [Command: start]
06/19/06 22:23:18.436651 zmpkg[9589].ERR [Unable to find valid 'su' syntax]
06/19/06 22:25:15.671046 zmpkg[11074].INF [Command: start]
==> /tmp/zmwatch.log <==
06/19/06 22:45:33.243525 zmwatch[11129].INF ['zmc -d /dev/video0' started at 06/
06/19 22:45:33] at /usr/bin/zmwatch.pl line 118
06/19/06 22:45:43.250753 zmwatch[11129].INF [Restarting capture daemon for Drive
way, shared memory not valid]
06/19/06 22:45:43.673169 zmwatch[11129].INF ['zmc -d /dev/video1' started at 06/
06/19 22:45:43] at /usr/bin/zmwatch.pl line 118
06/19/06 22:45:43.675632 zmwatch[11129].INF [Restarting capture daemon for video
0, shared memory not valid]
06/19/06 22:45:44.150170 zmwatch[11129].INF ['zmc -d /dev/video0' started at 06/
06/19 22:45:44] at /usr/bin/zmwatch.pl line 118
06/19/06 22:45:54.155615 zmwatch[11129].INF [Restarting capture daemon for Drive
06/19/06 22:45:54.580313 zmwatch[11129].INF ['zmc -d /dev/video1' starting at 06
/06/19 22:45:54, pid = 12755] at /usr/bin/zmwatch.pl line 118
06/19/06 22:45:54.582832 zmwatch[11129].INF [Restarting capture daemon for video
06/19/06 22:45:54.996271 zmwatch[11129].INF ['zmc -d /dev/video0' started at 06/
06/19 22:45:54] at /usr/bin/zmwatch.pl line 118
06/19/06 22:46:05.000329 zmwatch[11129].INF [Restarting capture daemon for Drive
now i tried to get 1.22.2 from source and do it myself
~/ZoneMinder-1.22.2/
./configure --with-webdir=/var/www/localhost/htdocs/zoneminder/ --with-cgidir=/var/www/localhost/cgi-bin/ --with-webuser=apache --with-webdir=/var/www/localhost/htdocs/ --with-webgroup=apache --with-ffmpeg=/usr/local/ --with-mysql --with-extralibs
make.. make install
$ tail /tmp/zm*.log
06/19/06 22:55:22.464423 zmaudit[11124].DBG [Found database monitor '2']
06/19/06 22:55:22.465016 zmaudit[11124].DBG [Got 0 events]
06/19/06 23:10:22.470332 zmaudit[11124].DBG [Found database monitor '1']
06/19/06 23:10:22.471092 zmaudit[11124].DBG [Got 0 events]
06/19/06 23:10:22.471338 zmaudit[11124].DBG [Found database monitor '2']
06/19/06 23:10:22.471931 zmaudit[11124].DBG [Got 0 events]
06/19/06 23:25:22.478660 zmaudit[11124].DBG [Found database monitor '1']
06/19/06 23:25:22.479594 zmaudit[11124].DBG [Got 0 events]
06/19/06 23:25:22.479847 zmaudit[11124].DBG [Found database monitor '2']
06/19/06 23:25:22.480439 zmaudit[11124].DBG [Got 0 events]
Use of uninitialized value in sprintf at /usr/lib/perl5/site_perl/5.8.8/ZoneMin
Debug.pm line 283.
Use of uninitialized value in sprintf at /usr/lib/perl5/5.8.8/i686-linux/Sys/Sy
.pm line 680.
Can't exec "/usr/bin/zmdc.pl": No such file or directory at /usr/bin/zmwatch.pl
e 118.
Use of uninitialized value in substitution (s///) at /usr/lib/perl5/site_perl/5
/ZoneMinder/Debug.pm line 278.
Debug.pm line 283.
.pm line 680.
e 118.
Debug.pm line 283.
.pm line 680.
06/19/06 23:28:21.040613 zmwatch[11129].INF [Restarting capture daemon for vide
06/19/06 23:28:21.043320 zmwatch[11129].INF []
06/19/06 23:28:31.047512 zmwatch[11129].INF [Restarting capture daemon for Driv
06/19/06 23:28:31.050296 zmwatch[11129].INF []
06/19/06 23:28:31.051982 zmwatch[11129].INF [Restarting capture daemon for vide
06/19/06 23:28:31.055553 zmwatch[11129].INF []
06/19/06 23:28:41.059932 zmwatch[11129].INF [Restarting capture daemon for Driv
06/19/06 23:28:41.063605 zmwatch[11129].INF []
06/19/06 23:28:41.064945 zmwatch[11129].INF [Restarting capture daemon for vide
06/19/06 23:28:41.068329 zmwatch[11129].INF []
the memory errors are interesting .. I believe i has SHM enabled..
$ cat /proc/sys/kernel/shmall
2097152
$ cat /proc/sys/kernel/shmmax
33554432
For the manual install I had to cp -a web/* /var/ww/localhost/htdocs/zoneminder/, and also edit the mysql_pconnect line to the mysql user/pass since zm dosent seemt to read /etc/zm.conf anymore.. but of course.. no steaming/stills from the cam in zm
thanks
