Is there a way to change a camera mode directly from command line without the creation of a new state?
thank you for your help!
control camera modes independently from command line
wel i havnt checked the docs as i have never need to do this but i suppose you 'could' edit the db with a command, then restat zm with a command if you really have to
James Wilson
Ok thank you. There were some suggestions in previous postings long time ago that it was possible but maybe then it isnt.
I guess I have to look into changing the db from scripts or manually starting the zmc and zma daemons from scripts.
I have to control 10+ cameras independently and on irregular intervals so therefore I am looking for a solution to this.
-h
-h
You could duplicate your cameras if needed if that helps
ie have 2 cam1 one as mocord one as record etc
James Wilson
Something like this
echo "UPDATE Monitors SET Function='Modect' WHERE Id='1'" |mysql -u zmuser -pzmpass zm && zmpkg.pl restart
- zoneminder
- Site Admin
- Contact:
