I'm building the Zoneminder 1.22.2 on an arm-xscale using Montavista Linux, but when I get to the compiling of zmc, I get the following error:
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/local/mysql/include -I/usr/include -I/usr/local/mysql/include -g -O2 -MT zm_jpeg.o -MD -MP -MF ".deps/zm_
jpeg.Tpo" -c -o zm_jpeg.o zm_jpeg.c; \
then mv -f ".deps/zm_jpeg.Tpo" ".deps/zm_jpeg.Po"; else rm -f ".deps/zm_jpeg.Tpo"; exit 1; fi
zm_jpeg.c: In function `jpeg_mem_src':
zm_jpeg.c:392: warning: assignment discards qualifiers from pointer target type
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/local/mysql/include -I/usr/include -I/usr/local/mysql/include -lm -MT zm_regexp.o -MD -MP -MF ".deps/zm_r
egexp.Tpo" -c -o zm_regexp.o zm_regexp.cpp; \
then mv -f ".deps/zm_regexp.Tpo" ".deps/zm_regexp.Po"; else rm -f ".deps/zm_regexp.Tpo"; exit 1; fi
gcc: -lm: linker input file unused because linking not done
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/local/mysql/include -I/usr/include -I/usr/local/mysql/include -lm -MT zm_signal.o -MD -MP -MF ".deps/zm_s
ignal.Tpo" -c -o zm_signal.o zm_signal.cpp; \
then mv -f ".deps/zm_signal.Tpo" ".deps/zm_signal.Po"; else rm -f ".deps/zm_signal.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/local/mysql/include -I/usr/include -I/usr/local/mysql/include -lm -MT zm_buffer.o -MD -MP -MF ".deps/zm_b
uffer.Tpo" -c -o zm_buffer.o zm_buffer.cpp; \
then mv -f ".deps/zm_buffer.Tpo" ".deps/zm_buffer.Po"; else rm -f ".deps/zm_buffer.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/local/mysql/include -I/usr/include -I/usr/local/mysql/include -g -O2 -MT zm_debug.o -MD -MP -MF ".deps/zm
_debug.Tpo" -c -o zm_debug.o zm_debug.c; \
then mv -f ".deps/zm_debug.Tpo" ".deps/zm_debug.Po"; else rm -f ".deps/zm_debug.Tpo"; exit 1; fi
gcc -lm -L/usr/lib -L/usr/local/mysql/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone
.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm
_debug.o -lmysqlclient -ldl -lz -ljpeg
zmc.o(.text+0x5bc): In function `main':
: undefined reference to `operator new[](unsigned)'
zmc.o(.text+0x6b8): In function `main':
zmc.o(.text+0x6cc): In function `main':
zmc.o(.text+0x6e0): In function `main':
zmc.o(.text+0x6f4): In function `main':
zmc.o(.text+0xd10): In function `main':
: undefined reference to `operator delete(void*)'
zmc.o(.text+0xd34): In function `main':
: undefined reference to `operator delete[](void*)'
zmc.o(.text+0xd48): In function `main':
zmc.o(.text+0xd5c): In function `main':
zm_config.o(.text+0x468): In function `ConfigItem::ConfigItem[unified](char const*, char const*, char const*)':
zm_config.o(.text+0x498): In function `ConfigItem::ConfigItem[unified](char const*, char const*, char const*)':
zm_config.o(.text+0x4c8): In function `ConfigItem::ConfigItem[unified](char const*, char const*, char const*)':
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
I use:
CC=gcc CXX=gcc CFLAGS="-lm" CXXFLAGS="-lm" CPPFLAGS="-I/usr/local/mysql/include" ./configure --with-webdir=/opt/www/htdocs/html --with-cgidir=/opt/www/htdocs/cgi-bin --with-webuser=www --with-webgroup=www --with-mysql=/usr/local/mysql --disable-crashtrace ZM_DB_USER=zm ZM_DB_PASS=zm ZM_DB_NAME=zone
If you are wondering about any of the options, -lm used in order for libmysqlclient to work and CXX=gcc to get libjpeg to work (think g++ is broken).
Hope somebody can help me as I have no clue whatsoever how to approach this..
Regards, Jon
