Automatical Videostream generation
essup
Post by essup »
my request is simple:
After ZM did some record, i want ZM do generate a videostream from the jpeg's and finally delete the jpeg's. I don't care how it is done, i don't care if ffmpeg runs with +19 priority. Is there a way to do this? And if not, where do i have to start hacking the sources to get my script done?
jameswilson
Post by jameswilson »
Id start your search here
http://www.zoneminder.com/forums/viewto ... sc&start=0
But id also be very careful of doing this in a 'nonstandard' way as if you do change the source your gonna be more or less on your own. I read on here about someone posting ascript that generted a vid and moved it to a centrol folder with folders for each da. Be carefull if you dont move the video file when you use a filter to delete 'all' events it will wipe out your vids too!
James Wilson
