btv green screen
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
stealth
btv green screen
Post by stealth »
After giving up on ZM+Gentoo Im trying this liveCD. I added the options bttv tuner=-1 card=102,102,102,102,102,102,102,102 in /etc/modprobe.conf which did work in tvtime/xawtv in Gentoo, but now all I get are icons on the desktop and half a green screen, the other half it seems part of a broken image of the cam.. :?:
stealth
Post by stealth »
note... I was able to edit the file since i installed it to hd... couldent seem to unprobe the modules correctly to reprobe bttv with the right card options, so.. i installed to hd, edited the modprobe.conf file, and restarted...
stealth
Post by stealth »
ok it seems my kodicom card (i think it is) is only supported in 2.6.16.. which the live cd install didnt come with originall, urpmi-ing the new one only screws it up.. so yea with gentoo I had a image in xawtv and tvtime yet zm didnt work, now in mandriva zm works but the cam dosent... super
jameswilson
Post by jameswilson »
isnt the new zmlive cd based on 2.6.16 or is it 15
James Wilson
rdmelin
Post by rdmelin »
Yes the new ZMliveCD_1.22.2 has a 2.6.16.17 kernel so kodicom cards will (I hope) be well supported, though I do not have one to test yet.
stealth
Post by stealth »
i have 1.22.2 but it boots 2.6.7, there is nothing resembling 2.6.16 in /boot
jameswilson
you have the old live cd then. That was originaly 1.21.x based
There is a new one based on 1.22.x and the kernels stated above on madrake 2006
James Wilson
