Page 1 of 1
btv green screen
Posted: Thu Jun 22, 2006 3:16 am
by stealth
After giving up on ZM+Gentoo Im trying this liveCD. I added the options bttv tuner=-1 card=102,102,102,102,102,102,102,102 in /etc/modprobe.conf which did work in tvtime/xawtv in Gentoo, but now all I get are icons on the desktop and half a green screen, the other half it seems part of a broken image of the cam..
Posted: Thu Jun 22, 2006 3:17 am
by stealth
note... I was able to edit the file since i installed it to hd... couldent seem to unprobe the modules correctly to reprobe bttv with the right card options, so.. i installed to hd, edited the modprobe.conf file, and restarted...
Posted: Fri Jun 23, 2006 12:55 pm
by stealth
ok it seems my kodicom card (i think it is) is only supported in 2.6.16.. which the live cd install didnt come with originall, urpmi-ing the new one only screws it up.. so yea with gentoo I had a image in xawtv and tvtime yet zm didnt work, now in mandriva zm works but the cam dosent... super
Posted: Fri Jun 23, 2006 3:10 pm
by jameswilson
isnt the new zmlive cd based on 2.6.16 or is it 15
Posted: Fri Jun 23, 2006 7:38 pm
by rdmelin
Yes the new ZMliveCD_1.22.2 has a 2.6.16.17 kernel so kodicom cards will (I hope) be well supported, though I do not have one to test yet.
Posted: Fri Jun 23, 2006 9:07 pm
by stealth
i have 1.22.2 but it boots 2.6.7, there is nothing resembling 2.6.16 in /boot
Posted: Fri Jun 23, 2006 9:12 pm
by jameswilson
you have the old live cd then. That was originaly 1.21.x based
There is a new one based on 1.22.x and the kernels stated above on madrake 2006
