Thanks for your response.
I try to provide you as much info as i can:
How I set up my first cam, an Axis 205 (IP-Cam, without authentication, so I can access the Link
http://192.168.0.110/axis-cgi/mjpg/video.cgi without problems):
General:
- Source Type: Remote
- Function: Monitor
- Enabled: yes
Source:
- Remote Host Name: 192.168.0.111
- Port: 80
- Path: /axis-cgi/mjpg/video.cgi
- Remote Image Colours: 24 Bit colour
- Width: 640
- Height: 480
- Orientation: Normal
Buffers & Misc:
nothing changed
Meanwhile I have checked the logs:
Jun 22 11:09:13 zoneminder zmdc[19526]: INF [Starting pending process, zmc -m 1]
Jun 22 11:09:13 zoneminder zmdc[19526]: INF ['zmc -m 1' starting at 06/06/22 11:09:13, pid = 24454]
Jun 22 11:09:13 zoneminder zmdc[24454]: INF ['zmc -m 1' started at 06/06/22 11:09:13]
Jun 22 11:09:13 zoneminder zmc_m1[24454]: INF [Debug Level = 0, Debug Log = <none>]
Jun 22 11:09:13 zoneminder zmc_m1[24454]: INF [Starting Capture]
Jun 22 11:09:13 zoneminder zmc_m1[24454]: WAR [Unable to use netcam regexps as not compiled with libpcre]
So I did apt-get install the libpcre package, compiled zm again.
I deleted zm database, created a new one (with the SQL script) and created a new monitor - but when I do a
tail -f zm* in /tmp/, i get the following:
==> zmdc.log <==
22.06.2006 12:26:08.109007 zmdc[29592].ERR ['zmc -m 2' exited abnormally, exit status 255]
22.06.2006 12:26:18.395158 zmdc[29592].INF ['zmc -m 2' starting at 06/06/22 12:26:18, pid = 29742]
22.06.2006 12:26:18.398209 zmdc[29742].INF ['zmc -m 2' started at 06/06/22 12:26:18]
22.06.2006 12:26:18.434931 zmdc[29592].ERR ['zmc -m 2' exited abnormally, exit status 255]
22.06.2006 12:26:28.691964 zmdc[29592].INF ['zmc -m 2' starting at 06/06/22 12:26:28, pid = 29746]
22.06.2006 12:26:28.694754 zmdc[29746].INF ['zmc -m 2' started at 06/06/22 12:26:28]
22.06.2006 12:26:28.730633 zmdc[29592].ERR ['zmc -m 2' exited abnormally, exit status 255]
22.06.2006 12:26:39.040770 zmdc[29592].INF ['zmc -m 2' starting at 06/06/22 12:26:39, pid = 29750]
22.06.2006 12:26:39.043620 zmdc[29750].INF ['zmc -m 2' started at 06/06/22 12:26:39]
22.06.2006 12:26:39.072105 zmdc[29592].ERR ['zmc -m 2' exited abnormally, exit status 255]
tail: ,,zmdc.sock" kann nicht zum Lesen geöffnet werden: Kein passendes Gerät bzw. keine passende Adresse gefunden
==> zmfilter.log <==
21.06.2006 18:18:27.761214 zmfilter[19549].INF [Scanning for events]
22.06.2006 12:22:40.397710 zmfilter[29621].INF [Scanning for events]
==> zmpkg.log <==
21.06.2006 18:18:22.183707 zmpkg[19511].INF [Command: start]
22.06.2006 07:34:31.167623 zmpkg[22465].INF [Command: start]
22.06.2006 11:15:43.067175 zmpkg[24484].INF [Command: stop]
22.06.2006 11:17:42.552961 zmpkg[24528].INF [Command: stop]
22.06.2006 12:22:32.317710 zmpkg[29574].INF [Command: restart]
==> zmupdate.log <==
21.06.2006 18:18:28.835230 zmupdate[19563].INF [Checking for updates]
21.06.2006 18:18:29.191382 zmupdate[19563].INF [Got version: '1.22.2']
22.06.2006 12:22:42.133440 zmupdate[29635].INF [Checking for updates]
22.06.2006 12:22:42.440224 zmupdate[29635].INF [Got version: '1.22.2']
==> zmwatch.log <==
22.06.2006 12:26:08.104407 zmwatch[29631].INF ['zmc -m 2' started at 06/06/22 12:26:08] at /usr/local/bin/zmwatch.pl line 118
22.06.2006 12:26:18.109819 zmwatch[29631].ERR [Can't get shared memory id '7a6d2002', 2: Datei oder Verzeichnis nicht gefunden]
22.06.2006 12:26:18.110074 zmwatch[29631].INF [Restarting capture daemon for test, shared memory not valid]
22.06.2006 12:26:18.423867 zmwatch[29631].INF ['zmc -m 2' starting at 06/06/22 12:26:18, pid = 29742] at /usr/local/bin/zmwatch.pl line 118
22.06.2006 12:26:28.429682 zmwatch[29631].ERR [Can't get shared memory id '7a6d2002', 2: Datei oder Verzeichnis nicht gefunden]
22.06.2006 12:26:28.429942 zmwatch[29631].INF [Restarting capture daemon for test, shared memory not valid]
22.06.2006 12:26:28.716308 zmwatch[29631].INF ['zmc -m 2' started at 06/06/22 12:26:28] at /usr/local/bin/zmwatch.pl line 118
22.06.2006 12:26:38.728236 zmwatch[29631].ERR [Can't get shared memory id '7a6d2002', 2: Datei oder Verzeichnis nicht gefunden]
22.06.2006 12:26:38.728497 zmwatch[29631].INF [Restarting capture daemon for test, shared memory not valid]
22.06.2006 12:26:39.081970 zmwatch[29631].INF ['zmc -m 2' started at 06/06/22 12:26:39] at /usr/local/bin/zmwatch.pl line 118
==> zmdc.log <==
22.06.2006 12:26:49.374805 zmdc[29592].INF ['zmc -m 2' starting at 06/06/22 12:26:49, pid = 29755]
22.06.2006 12:26:49.377616 zmdc[29755].INF ['zmc -m 2' started at 06/06/22 12:26:49]
22.06.2006 12:26:49.413206 zmdc[29592].ERR ['zmc -m 2' exited abnormally, exit status 255]
==> zmwatch.log <==
22.06.2006 12:26:49.109988 zmwatch[29631].ERR [Can't get shared memory id '7a6d2002', 2: Datei oder Verzeichnis nicht gefunden]
22.06.2006 12:26:49.110256 zmwatch[29631].INF [Restarting capture daemon for test, shared memory not valid]
22.06.2006 12:26:49.396763 zmwatch[29631].INF ['zmc -m 2' starting at 06/06/22 12:26:49, pid = 29755] at /usr/local/bin/zmwatch.pl line 118
What's happening here?
Thank you very much!
Simon
