MOCORD Setting....
Dr_AxiA
MOCORD Setting....
Post by Dr_AxiA »
Hi all!! If I have to set MOCORD mode to record only frame which ZM determine in motion, what have I do???
I have set the source camera in MOCORD mode and I set the Zone (I try in active and preclusive mode)...but nothing...
Are there other specific parameter to set ???
Thanks....
jameswilson
Post by jameswilson »
well by the sounds of it you want ot use modect. and you need to ensure your zone settings are correct. There are plenty of posts on here about it.
Once done that will do (i think) what you want
James Wilson
Dr_AxiA
Post by Dr_AxiA »
thanks....therefore in summary… MODECT mode ONLY records the frames of the event that comes determines to you in motion detection, MOCORD mode records all the frame of the event and evidences in red only those finds to you like motion detection?
Therefore for this, have I try only setting a correct zone for the source??
jameswilson
yes thats correct. Once you hace your zone(s) setting correct it will work
James Wilson
Dr_AxiA
Post by Dr_AxiA »
