crontab and running state not working
ynn
Post by ynn »
I have created crontab and running state called Morning and Night
crontab -l
10 6 * * * root /usr/local/bin/zmpkg.pl Morning
10 20 * * * root /usr/local/bin/zmpkg.pl Night
crond is running and cron.allow is already created
but the running state is not changed after the time passed.
do i need to run or create anything else to make cron working?
thanks.
voronwe
Post by voronwe »
Hi ynn
If my memory serves me right then what you need to change is the following. :
10 6 * * * root /usr/local/bin/zmpkg.pl 'Morning'
10 20 * * * root /usr/local/bin/zmpkg.pl 'Night'
The changes are the little ' surrounding the state name.
Best Regards
Tom Stage
Flash_
Post by Flash_ »
Shouldn't need the quotes - but the state IS case-sensitive.
Also I never specified a user, but that shouldn't be the problem.
Does it work when you run zmpkg.pl from the command line to switch states?
ynn
Post by ynn »
Yeah I just got it worked out with these:
10 7 * * * /usr/bin/sudo -u apache /usr/local/bin/zmpkg.pl Morning >> /root/logfile.txt 2>&1
10 17 * * * /usr/bin/sudo -u apache /usr/local/bin/zmpkg.pl Night >> /root/logfile.txt 2>&1
Thanks.
Flash_
Post by Flash_ »
Ahh, sudo. Ubuntu by chance? :)
ynn
Post by ynn »
been using Centos4.3, have never been using ubuntu. is it better than fedora ?
Flash_
Post by Flash_ »
Ah, sorry. The sudo thing is something that marks Ubuntu out as different in usage to many other distros, i didn't know Centos used sudo too.
Glad you got it sorted out.
cordel
Post by cordel »
Actually sudo in in most distro's or I should say that I know it is in Mandriva/Mandrake, Suse, Fedora/RedHat/CentOS, Debian, and Ubuntu. It's part of the common command set for Linux.
Regards,
Corey
Flash_
Post by Flash_ »
In most distros, but not installed by default (certainly not Debian).
My reason for mentioning Ubuntu is because that uses only sudo, not su at all - and it's a common problem that crops up in many web forums for people coming from other distros to it. This would've applied to crontab as in most distros you'd use root's crontab, or zmuser's crontab to invoke zmpkg.pl to change states, and using root's crontab doesn't work with ubuntu (afaik) simply because it doesn't have a root account.
But, as you can see, I was wrong. :)
