zm_mpeg compile error: 'struct AVCodecContext**"
This issue has previously cropped up here but as the last post in the thread was in april with a complaint of the issue resurfacing I am starting a new thread:
http://www.zoneminder.com/forums/viewto ... deccontext
I am using ZoneMinder-1.22.2, and ffmpeg from SVN (centos 4.3 on a P3) checked out this morning. The compile is dieing as follows:
then mv -f ".deps/zm_user.Tpo" ".deps/zm_user.Po"; else rm -f ".deps/zm_user.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/include -g -O2 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
zm_mpeg.cpp: In member function `void VideoStream::SetupCodec(int, int, int, int, int)':
zm_mpeg.cpp:88: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp:109: error: 'struct AVCodecContext' has no member named 'frame_rate'
zm_mpeg.cpp:110: error: 'struct AVCodecContext' has no member named 'frame_rate_base'
zm_mpeg.cpp: In member function `void VideoStream::OpenStream()':
zm_mpeg.cpp:161: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp: In destructor `VideoStream::~VideoStream()':
zm_mpeg.cpp:256: error: cannot convert `AVCodecContext**' to `AVCodecContext*' for argument `1' to `int avcodec_close(AVCodecContext*)'
zm_mpeg.cpp: In member function `double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)':
zm_mpeg.cpp:303: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.22.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.22.2'
- zoneminder
- Site Admin
- Contact:
zm_mpeg.h
Well here is the garbage that spewed forth AFTER I applied the patch with no reported error. This has turned into a real science project.
zm_mpeg.cpp: In member function ‘void VideoStream::SetupCodec(int, int, int, int, int)’:
zm_mpeg.cpp:88: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
zm_mpeg.cpp:109: error: ‘struct AVCodecContext’ has no member named ‘frame_rate’
zm_mpeg.cpp:110: error: ‘struct AVCodecContext’ has no member named ‘frame_rate_base’
zm_mpeg.cpp: In member function ‘void VideoStream::OpenStream()’:
zm_mpeg.cpp:161: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
zm_mpeg.cpp: In destructor ‘VideoStream::~VideoStream()’:
zm_mpeg.cpp:256: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ for argument ‘1’ to ‘int avcodec_close(AVCodecContext*)’
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:303: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
make[2]: Leaving directory `/usr/local/ZoneMinder-1.22.2/src'
make[1]: Leaving directory `/usr/local/ZoneMinder-1.22.2'
make: *** [all] Error 2
DidI apply the patch wrong? WTF?
Anyway, HELP!
Anyway, HELP!
how did you fix it?
James Wilson
re patch
Applied the patch, re-configured, re-made, re-installed. It works fine but only grayscale works. Funny the color works when running xawtv. Source goes red on the console and video stops when trying rgb24. Probably some tweak I haven't found yet.
are your running at a res higher than 320x240?
James Wilson
color
Running 320X240 on all 6 CCD cameras. Same res displays color on all cams when looking through the BTTV card with xawtv. I have 3 BTTV cards in this PC, all clones bought on E-Bay. I'm probably missing a tewak somewhere, and theres planty of them in this package. Took me about a week of playing to get it running as it is. Grayscale pix looks good.
and you have set all the paleets to 24 bit? That is wierd
James Wilson
fixed
Well I found the trick. I set all sources to RGB24 and restarted ZM. Now I have color on all cam feeds. I'm gonna screw with motion detection, recording, and web access later. Basking in this small victory for now.
