Axis 205/206 greyscale image
simonm
Post by simonm »
i am thinking of setting all my axis cams to greyscale, because it takes less CPU power.
But - it seems to me that i cant change from 24 bit color to greyscale? Does axis only support 24 bit color in model 205/206?
Thanks,
Simon
jameswilson
Post by jameswilson »
You will need to tell zm to expect a mono image and reconfigure your camera to send mono images, you need to do both
James Wilson
simonm
Post by simonm »
Hi James,
in zm i can define 24bit color / greyscale, thats clear.
But i did not find this setting in the webinterface of the cam.
Update: calling the URL
[IP]/axis-cgi/mjpg/video.cgi?resolution=640x480&color=0
gives me a greyscale image.
Thanks!!!
Simon
Flash_
Post by Flash_ »
The Axis cams have a lovely interface where you can specify colour, size, jpeg compression etc and it'll produce a url for you to use. Handy feature!
simonm
Post by simonm »
Thanks, that's the way I found it out. By the way you say "lovely interface":
Nice feature is the "script editor": you can edit files of the embedded linux. My cams are now able to syslog.... :D
Axis rules :-)
Regards,
Simon
