Page 1 of 1
Axis 205/206 greyscale image
Posted: Thu Jul 06, 2006 4:31 pm
by simonm
i am thinking of setting all my axis cams to greyscale, because it takes less CPU power.
But - it seems to me that i cant change from 24 bit color to greyscale? Does axis only support 24 bit color in model 205/206?
Thanks,
Simon
Posted: Thu Jul 06, 2006 5:26 pm
by jameswilson
You will need to tell zm to expect a mono image and reconfigure your camera to send mono images, you need to do both
Posted: Thu Jul 06, 2006 5:37 pm
by simonm
Hi James,
in zm i can define 24bit color / greyscale, thats clear.
But i did not find this setting in the webinterface of the cam.
Update: calling the URL
[IP]/axis-cgi/mjpg/video.cgi?resolution=640x480&color=0
gives me a greyscale image.
Thanks!!!
Simon
Posted: Fri Jul 07, 2006 6:27 am
by Flash_
The Axis cams have a lovely interface where you can specify colour, size, jpeg compression etc and it'll produce a url for you to use. Handy feature!
Posted: Fri Jul 07, 2006 6:57 am
by simonm
Thanks, that's the way I found it out. By the way you say "lovely interface":
Nice feature is the "script editor": you can edit files of the embedded linux. My cams are now able to syslog.... :D
Axis rules :-)
Regards,
Simon
