Page 1 of 2
anyone knows Brooktree Bt878 card?
Posted: Tue Jul 11, 2006 3:59 pm
by julien
Dear all,
I am testing a DVR card (buy in local black-market, don't have any mark) based on bt878, actually have 8 channel, but when i try:
zmu -d /dev/video0 -q -v: i only see 4 channel.
The problem is that when i try to config zoneminde with:
from /dev/video0(0) to /dev/video3(0), i see the fps about: 20fps- - 40fps but don't see any picture just only blue screen. Surely, i connected some good cctv camera.
Any idea will be very apperciated?
1- when i try: zmu -d /dev/video0 -q -v --> i get:
Video Capabilities
Name: BT878 video (Leadtek WinFast 20
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 7 - YUV422 capture
Colour Depth: 16
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
2. when i try: xawtw -hwscan --> i get:
This is xawtv-3.94, running on Linux/i686 (2.6.16.17.rdm1.smp)
looking for available devices
port 65-65 [ -xvport 65 ]
type : Xvideo, video overlay
port 66-66 [ -xvport 66 ]
port 67-67 [ -xvport 67 ]
port 68-68 [ -xvport 68 ]
port 69-69
type : Xvideo, image scaler
name : NV Video Overlay
port 70-101
name : NV Video Blitter
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (Leadtek WinFast 20
flags: overlay capture tuner
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
name : BT878 video ( *** UNKNOWN/GENER
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
3. when i try dmesg | grep bttv --> i get:
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 5, latency: 64, mmio: 0xf7efe000
bttv0: using: Leadtek WinFast 2000/ WinFast 2000 XP [card=34,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=24
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: registered device radio0
bttv0: PLL: 28636363 => 35468950 .. ok
input: bttv IR (card=34) as /class/input/input2
bttv-input: bttv IR (card=34) detected at pci-0000:03:08.0/ir0
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:03:09.0, irq: 10, latency: 64, mmio: 0xf7efc000
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for MSP34xx @ 0x80... not found
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:03:0a.0, irq: 11, latency: 64, mmio: 0xf7efa000
bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for MSP34xx @ 0x80... not found
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:03:0b.0, irq: 5, latency: 64, mmio: 0xf7ef8000
bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for MSP34xx @ 0x80... not found
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv: Bt8xx card found (4).
bttv4: Bt878 (rev 17) at 0000:03:0c.0, irq: 5, latency: 64, mmio: 0xf7ef6000
bttv4: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv4: using tuner=-1
bttv4: i2c: checking for MSP34xx @ 0x80... not found
bttv4: i2c: checking for TDA9875 @ 0xb0... not found
bttv4: i2c: checking for TDA7432 @ 0x8a... not found
bttv4: i2c: checking for TDA9887 @ 0x86... not found
bttv4: registered device video4
bttv4: registered device vbi4
bttv: Bt8xx card found (5).
bttv5: Bt878 (rev 17) at 0000:03:0d.0, irq: 10, latency: 64, mmio: 0xf7ef4000
bttv5: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv5: using tuner=-1
bttv5: i2c: checking for MSP34xx @ 0x80... not found
bttv5: i2c: checking for TDA9875 @ 0xb0... not found
bttv5: i2c: checking for TDA7432 @ 0x8a... not found
bttv5: i2c: checking for TDA9887 @ 0x86... not found
bttv5: registered device video5
bttv5: registered device vbi5
bttv: Bt8xx card found (6).
bttv6: Bt878 (rev 17) at 0000:03:0e.0, irq: 11, latency: 64, mmio: 0xf7ef2000
bttv6: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv6: using tuner=-1
bttv6: i2c: checking for MSP34xx @ 0x80... not found
bttv6: i2c: checking for TDA9875 @ 0xb0... not found
bttv6: i2c: checking for TDA7432 @ 0x8a... not found
bttv6: i2c: checking for TDA9887 @ 0x86... not found
bttv6: registered device video6
bttv6: registered device vbi6
bttv: Bt8xx card found (7).
bttv7: Bt878 (rev 17) at 0000:03:0f.0, irq: 5, latency: 64, mmio: 0xf7ef0000
bttv7: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv7: using tuner=-1
bttv7: i2c: checking for MSP34xx @ 0x80... not found
bttv7: i2c: checking for TDA9875 @ 0xb0... not found
bttv7: i2c: checking for TDA7432 @ 0x8a... not found
bttv7: i2c: checking for TDA9887 @ 0x86... not found
bttv7: registered device video7
bttv7: registered device vbi7
Many thanks if you have any idea.
Posted: Tue Jul 11, 2006 4:04 pm
by jameswilson
from the info posted it looks like an 8 chip card. You will need to find out what it is to get it to work in linux as its not autodetected. If you have an serial numbers model numbers etc id start there with google!
continues...
Posted: Tue Jul 11, 2006 4:12 pm
by julien
Dear all,
I try with a new monitor from source: /dev/video7(0). Now i can get the picture but it's very bad. Don't have any color and it make three flashing same small image in the screen.
I am using: PAL RGB24...
Any idea will be very appreciated.
Julien
some new success
Posted: Tue Jul 11, 2006 4:15 pm
by julien
Dear all,
Now with NTSC RGB24, i have better image but without color.
Any idea will be very appreciated...
Julien
Posted: Tue Jul 11, 2006 4:30 pm
by jameswilson
you will still need to tell linux exactly what card it is although you could try edding your modprobe.conf and adding
options bttv card=77,77,77,77,77,77,77,77
James
hi
Posted: Wed Jul 12, 2006 10:35 am
by julien
Many thank jameswilson,
That's great. It work now.
julien
Posted: Wed Jul 12, 2006 10:56 am
by jameswilson
can you send me /us an image of your card so i / you can add it to the wiki as a known card?
Posted: Wed Jul 12, 2006 11:52 am
by cordel
also please run a scanpci -v please so we may properly list this card.
Cheers,
Corey
Posted: Fri Jul 21, 2006 7:42 pm
by magneto
Hi, i had the same problem with a 4 input inexpensive card
jameswilson wrote:you will still need to tell linux exactly what card it is although you could try edding your modprobe.conf and adding
James
the solution worked fine.
I still have some problems of image quality.
Thanks a lot anyway!
P.S.
What do those option actually do?
Greetings to all
Posted: Fri Jul 21, 2006 11:30 pm
by jameswilson
the 77 tells the bttv driver that each each chip is a type 77 device and forces that choice as autodetection of the cheaper kit usually fails to work (a kit issue not a bttv issue)
forcing to type 77 make sthem work in a certain way. All card supported under bttv have differnt card numbers
Posted: Tue Jul 25, 2006 8:44 pm
by magneto
hello,
first of all thanks for your answer.
then just for information, can these information be found in a readme or some kind of documentation that comes with the driver or comes from your experience?
my greetings to all and thanks to james.
Oh, by the way...
Pat Metheny Group published a tune called James in the "Offramp" album.
Very charming.
Perfect for listening while studying zoneminder and linux possibilities.
Oops...
Another question:
While performing monitoring of the four input of my cheap card i found that the average fps where around 2,25 per camera (with four cameras configured) and _25_ with only one configured. Another chipset or zoneminder feature? And could it be that giving bttv the exact device number the capability could improve? Or some other option in zoneminder?
If any of the answer are in some other post or in the documentation of zoneminder i apologize!
Bye and see you!
Posted: Tue Jul 25, 2006 8:57 pm
by jameswilson
If you have a single chip and switching between then 2.5 fps per input is about right. If you have multichips then its wrong and you have a setting configured wrong in the monitor settings
Posted: Mon Mar 19, 2007 6:59 pm
by Max Steel
I have the same Problem,
The card is GeoVision GV-250 8 Port.
With an BT787 Chip.
Quote of 'zmu -d /dev/video0 -q -v':
Video Capabilities
Name: BT878 video (GrandTec Multi Cap
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Colour Depth: 16
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 35090
Whiteness: 0
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Quote of 'dmesg | grep bttv':
bttv0: Bt878 (rev 17) at 0000:00:14.0, irq: 10, latency: 32, mmio: 0xde003000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: using tuner=-1
bttv0: PLL can sleep, using XTAL (28636363).
bttv0: OCERR @ 0362701c,bits: HSYNC OCERR*
bttv0: timeout: drop=7 irq=139777/139777, risc=07510024, bits: HSYNC FDSR
bttv0: reset, reinitialize
Quote of 'xawtw -hwscan':
-bash: xawtw: command not found
Quote of 'pciscan -v':
-bash: pciscan: command not found
Have you any Idea?
The Option card=77 is set, by me.
Edith:
Quote of '/var/log/messages':
Mar 17 18:38:17 test kernel: bttv: driver version 0.9.16 loaded
Mar 17 18:38:17 test kernel: bttv: using 8 buffers with 2080k (520 pages) each for capture
Mar 17 18:38:17 test kernel: bttv: Bt8xx card found (0).
Mar 17 18:38:17 test kernel: ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10 Mar 17 18:38:17 test kernel: bttv0: Bt878 (rev 17) at 0000:00:14.0, irq: 10, latency: 32, mmio: 0xde003000 Mar 17 18:38:17 test kernel: bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option] Mar 17 18:38:17 test kernel: bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init] Mar 17 18:38:17 test kernel: i2c-algo-bit.o: (0) scl=1, sda=1 Mar 17 18:38:17 test kernel: i2c-algo-bit.o: (1) scl=1, sda=0 Mar 17 18:38:17 test kernel: i2c-algo-bit.o: (2) scl=1, sda=1 Mar 17 18:38:17 test kernel: i2c-algo-bit.o: (3) scl=0, sda=1 Mar 17 18:38:17 test kernel: i2c-algo-bit.o: (4) scl=1, sda=1 Mar 17 18:38:18 test kernel: i2c-algo-bit.o: bt878 #0 [sw] passed test. Mar 17 18:38:18 test kernel: bttv0: using tuner=-1 Mar 17 18:38:18 test kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... not found Mar 17 18:38:18 test kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... not found Mar 17 18:38:18 test kernel: bttv0: i2c: checking for TDA9887 @ 0x86... not found Mar 17 18:38:18 test kernel: bttv0: registered device video0 Mar 17 18:38:18 test kernel: bttv0: registered device vbi0 Mar 17 18:38:18 test kernel: bttv0: PLL: 28636363 => 35468950 .. ok Mar 17 18:39:43 test kernel: bttv0: PLL can sleep, using XTAL (28636363). Mar 17 18:39:43 test kernel: bttv0: PLL: 28636363 => 35468950 .. ok Mar 17 18:52:36 test zmpkg[6130]: INF [Command: start] Mar 17 18:52:37 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/bin/true Mar 17 18:52:37 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl check Mar 17 18:52:38 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmfix Mar 17 18:52:38 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl startup Mar 17 18:52:39 test zmdc[6144]: INF [Server starting at 07/03/17 18:52:39] Mar 17 18:52:42 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl start zmc -d /dev/video Mar 17 18:52:43 test zmdc[6168]: INF ['zmc -d /dev/video' started at 07/03/17 18:52:43] Mar 17 18:52:43 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 18:52:43, pid = 6168] Mar 17 18:52:43 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl start zmfilter.pl Mar 17 18:52:43 test zmc_dvideo[6168]: INF [Debug Level = 0, Debug Log = <none>] Mar 17 18:52:43 test zmc_dvideo[6168]: INF [Starting Capture] Mar 17 18:52:44 test zmdc[6144]: INF ['zmfilter.pl' starting at 07/03/17 18:52:44, pid = 6172] Mar 17 18:52:44 test zmdc[6172]: INF ['zmfilter.pl' started at 07/03/17 18:52:44] Mar 17 18:52:45 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl start zmaudit.pl -c
Mar 17 18:52:47 test zmdc[6144]: INF ['zmaudit.pl -c' starting at 07/03/17 18:52:47, pid = 6179]
Mar 17 18:52:47 test zmdc[6179]: INF ['zmaudit.pl -c' started at 07/03/17 18:52:47]
Mar 17 18:52:49 test zmfilter[6172]: INF [Scanning for events]
Mar 17 18:52:50 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zm
dc.pl start zmwatch.pl
Mar 17 18:52:54 test zmdc[6144]: INF ['zmwatch.pl' starting at 07/03/17 18:52:54, pid = 6189]
Mar 17 18:52:54 test zmdc[6189]: INF ['zmwatch.pl' started at 07/03/17 18:52:54]
Mar 17 18:52:56 test zmwatch[6189]: INF [Watchdog starting]
Mar 17 18:52:56 test zmwatch[6189]: INF [Watchdog pausing for 30 seconds]
Mar 17 18:52:56 test sudo: root : TTY=unknown ; PWD=/srv/www/htdocs/zm ; USER=wwwrun ; COMMAND=/usr/bin/zm
dc.pl start zmupdate.pl -c
Mar 17 18:52:57 test zmdc[6144]: INF ['zmupdate.pl -c' starting at 07/03/17 18:52:57, pid = 6198]
Mar 17 18:52:57 test zmdc[6198]: INF ['zmupdate.pl -c' started at 07/03/17 18:52:57]
Mar 17 18:53:01 test Update agent starting at 07/03/17 18:53:01
Mar 17 18:53:46 test zmc_dvideo[6168]: INF [Neu: 1000 - Capturing at 16.13 fps]
Mar 17 18:54:26 test zmc_dvideo[6168]: INF [Neu: 2000 - Capturing at 24.39 fps]
Mar 17 18:55:06 test zmc_dvideo[6168]: INF [Neu: 3000 - Capturing at 25.00 fps]
Mar 17 18:55:45 test zmc_dvideo[6168]: INF [Neu: 4000 - Capturing at 25.64 fps]
Mar 17 18:56:25 test zmc_dvideo[6168]: INF [Neu: 5000 - Capturing at 25.00 fps]
Mar 17 18:57:05 test zmc_dvideo[6168]: INF [Neu: 6000 - Capturing at 25.00 fps]
Mar 17 18:57:45 test zmc_dvideo[6168]: INF [Neu: 7000 - Capturing at 25.00 fps]
Mar 17 18:58:25 test zmc_dvideo[6168]: INF [Neu: 8000 - Capturing at 25.00 fps]
Mar 17 18:59:05 test zmc_dvideo[6168]: INF [Neu: 9000 - Capturing at 25.00 fps]
Mar 17 18:59:45 test zmc_dvideo[6168]: INF [Neu: 10000 - Capturing at 25.00 fps]
Mar 17 19:00:25 test zmc_dvideo[6168]: INF [Neu: 11000 - Capturing at 25.00 fps]
Mar 17 19:01:05 test zmc_dvideo[6168]: INF [Neu: 12000 - Capturing at 25.00 fps]
Mar 17 19:01:45 test zmc_dvideo[6168]: INF [Neu: 13000 - Capturing at 25.00 fps]
Mar 17 19:02:25 test zmc_dvideo[6168]: INF [Neu: 14000 - Capturing at 25.00 fps]
Mar 17 19:02:52 test zmdc[6144]: INF ['zmc -d /dev/video' stopping at 07/03/17 19:02:52]
Mar 17 19:02:52 test zmc_dvideo[6168]: INF [Got signal (Terminated), exiting]
Mar 17 19:02:52 test zmc_dvideo[6168]: ERR [Sync failure for frame 4 buffer 5(1): Interrupted system call]
Mar 17 19:02:52 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:02:53 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:02:53, pid = 6599]
Mar 17 19:02:53 test zmdc[6599]: INF ['zmc -d /dev/video' started at 07/03/17 19:02:53]
Mar 17 19:02:53 test zmc_dvideo[6599]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:02:53 test zmc_dvideo[6599]: INF [Starting Capture]
Mar 17 19:02:54 test zmdc[6144]: WAR [Can't find process with command of 'zma -m 4']
Mar 17 19:03:33 test zmc_dvideo[6599]: INF [Neu: 1000 - Capturing at 25.00 fps]
Mar 17 19:04:08 test kernel: bttv0: OCERR @ 0362701c,bits: HSYNC OCERR*
Mar 17 19:04:13 test zmc_dvideo[6599]: INF [Neu: 2000 - Capturing at 25.00 fps]
Mar 17 19:04:53 test zmc_dvideo[6599]: INF [Neu: 3000 - Capturing at 25.00 fps]
Mar 17 19:05:33 test zmc_dvideo[6599]: INF [Neu: 4000 - Capturing at 25.00 fps]
Mar 17 19:06:13 test zmc_dvideo[6599]: INF [Neu: 5000 - Capturing at 25.00 fps]
Mar 17 19:06:53 test zmc_dvideo[6599]: INF [Neu: 6000 - Capturing at 25.00 fps]
Mar 17 19:07:33 test zmc_dvideo[6599]: INF [Neu: 7000 - Capturing at 25.00 fps]
Mar 17 19:08:13 test zmc_dvideo[6599]: INF [Neu: 8000 - Capturing at 25.00 fps]
Mar 17 19:08:53 test zmc_dvideo[6599]: INF [Neu: 9000 - Capturing at 25.00 fps]
Mar 17 19:09:33 test zmc_dvideo[6599]: INF [Neu: 10000 - Capturing at 25.00 fps]
Mar 17 19:10:13 test zmc_dvideo[6599]: INF [Neu: 11000 - Capturing at 25.00 fps]
Mar 17 19:10:48 test kernel: bttv0: PLL can sleep, using XTAL (28636363).
Mar 17 19:10:49 test kernel: bttv0: timeout: drop=7 irq=139777/139777, risc=07510024, bits: HSYNC FDSR
Mar 17 19:10:49 test kernel: bttv0: reset, reinitialize
Mar 17 19:10:49 test kernel: bttv0: PLL can sleep, using XTAL (28636363).
Mar 17 19:10:49 test zmc_dvideo[6599]: ERR [Sync failure for frame 4 buffer 5(1): Input/output error]
Mar 17 19:10:49 test kernel: bttv0: PLL: 28636363 => 35468950 .. ok
Mar 17 19:10:50 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:10:50 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:10:50 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:10:50, pid = 7271]
Mar 17 19:10:50 test zmdc[7271]: INF ['zmc -d /dev/video' started at 07/03/17 19:10:50]
Mar 17 19:10:50 test zmc_dvideo[7271]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:10:51 test zmc_dvideo[7271]: INF [Starting Capture]
Mar 17 19:12:28 test zmc_dvideo[7271]: INF [Neu: 1000 - Capturing at 10.31 fps]
Mar 17 19:14:07 test zmc_dvideo[7271]: INF [Neu: 2000 - Capturing at 10.10 fps]
Mar 17 19:15:46 test zmc_dvideo[7271]: INF [Neu: 3000 - Capturing at 10.10 fps]
Mar 17 19:17:25 test zmc_dvideo[7271]: INF [Neu: 4000 - Capturing at 10.10 fps]
Mar 17 19:18:32 test zmc_dvideo[7271]: INF [Neu: 5000 - Capturing at 14.93 fps]
Mar 17 19:19:12 test zmc_dvideo[7271]: INF [Neu: 6000 - Capturing at 25.00 fps]
Mar 17 19:19:52 test zmc_dvideo[7271]: INF [Neu: 7000 - Capturing at 25.00 fps]
Mar 17 19:20:12 test zmd: ShutdownManager (WARN): Preparing to sleep...
Mar 17 19:20:13 test zmd: ShutdownManager (WARN): Going to sleep, waking up at 03/18/2007 18:10:08
Mar 17 19:20:32 test zmc_dvideo[7271]: INF [Neu: 8000 - Capturing at 25.00 fps]
Mar 17 19:21:11 test zmc_dvideo[7271]: INF [Neu: 9000 - Capturing at 25.64 fps]
Mar 17 19:21:51 test zmc_dvideo[7271]: INF [Neu: 10000 - Capturing at 25.00 fps]
Mar 17 19:22:31 test zmc_dvideo[7271]: INF [Neu: 11000 - Capturing at 25.00 fps]
Mar 17 19:23:11 test zmc_dvideo[7271]: INF [Neu: 12000 - Capturing at 25.00 fps]
Mar 17 19:23:19 test syslog-ng[4763]: STATS: dropped 0
Mar 17 19:23:51 test zmc_dvideo[7271]: INF [Neu: 13000 - Capturing at 25.00 fps]
Mar 17 19:24:31 test zmc_dvideo[7271]: INF [Neu: 14000 - Capturing at 25.00 fps]
Mar 17 19:25:11 test zmc_dvideo[7271]: INF [Neu: 15000 - Capturing at 25.00 fps]
Mar 17 19:25:51 test zmc_dvideo[7271]: INF [Neu: 16000 - Capturing at 25.00 fps]
Mar 17 19:26:31 test zmc_dvideo[7271]: INF [Neu: 17000 - Capturing at 25.00 fps]
Mar 17 19:27:11 test zmc_dvideo[7271]: INF [Neu: 18000 - Capturing at 25.00 fps]
Mar 17 19:27:51 test zmc_dvideo[7271]: INF [Neu: 19000 - Capturing at 25.00 fps]
Mar 17 19:28:31 test zmc_dvideo[7271]: INF [Neu: 20000 - Capturing at 25.00 fps]
Mar 17 19:29:11 test zmc_dvideo[7271]: INF [Neu: 21000 - Capturing at 25.00 fps]
Mar 17 19:29:51 test zmc_dvideo[7271]: INF [Neu: 22000 - Capturing at 25.00 fps]
Mar 17 19:30:31 test zmc_dvideo[7271]: INF [Neu: 23000 - Capturing at 25.00 fps]
Mar 17 19:31:11 test zmc_dvideo[7271]: INF [Neu: 24000 - Capturing at 25.00 fps]
Mar 17 19:31:51 test zmc_dvideo[7271]: INF [Neu: 25000 - Capturing at 25.00 fps]
Mar 17 19:32:31 test zmc_dvideo[7271]: INF [Neu: 26000 - Capturing at 25.00 fps]
Mar 17 19:33:11 test zmc_dvideo[7271]: INF [Neu: 27000 - Capturing at 25.00 fps]
Mar 17 19:33:51 test zmc_dvideo[7271]: INF [Neu: 28000 - Capturing at 25.00 fps]
Mar 17 19:34:31 test zmc_dvideo[7271]: INF [Neu: 29000 - Capturing at 25.00 fps]
Mar 17 19:35:11 test zmc_dvideo[7271]: INF [Neu: 30000 - Capturing at 25.00 fps]
Mar 17 19:35:51 test zmc_dvideo[7271]: INF [Neu: 31000 - Capturing at 25.00 fps]
Mar 17 19:36:31 test zmc_dvideo[7271]: INF [Neu: 32000 - Capturing at 25.00 fps]
Mar 17 19:37:11 test zmc_dvideo[7271]: INF [Neu: 33000 - Capturing at 25.00 fps]
Mar 17 19:37:51 test zmc_dvideo[7271]: INF [Neu: 34000 - Capturing at 25.00 fps]
Mar 17 19:38:31 test zmc_dvideo[7271]: INF [Neu: 35000 - Capturing at 25.00 fps]
Mar 17 19:39:10 test zmc_dvideo[7271]: INF [Neu: 36000 - Capturing at 25.64 fps]
Mar 17 19:39:50 test zmc_dvideo[7271]: INF [Neu: 37000 - Capturing at 25.00 fps]
Mar 17 19:40:30 test zmc_dvideo[7271]: INF [Neu: 38000 - Capturing at 25.00 fps]
Mar 17 19:41:10 test zmc_dvideo[7271]: INF [Neu: 39000 - Capturing at 25.00 fps]
Mar 17 19:41:50 test zmc_dvideo[7271]: INF [Neu: 40000 - Capturing at 25.00 fps]
Mar 17 19:42:30 test zmc_dvideo[7271]: INF [Neu: 41000 - Capturing at 25.00 fps]
Mar 17 19:43:10 test zmc_dvideo[7271]: INF [Neu: 42000 - Capturing at 25.00 fps]
Mar 17 19:43:50 test zmc_dvideo[7271]: INF [Neu: 43000 - Capturing at 25.00 fps]
Mar 17 19:44:30 test zmc_dvideo[7271]: INF [Neu: 44000 - Capturing at 25.00 fps]
Mar 17 19:45:10 test zmc_dvideo[7271]: INF [Neu: 45000 - Capturing at 25.00 fps]
Mar 17 19:45:50 test zmc_dvideo[7271]: INF [Neu: 46000 - Capturing at 25.00 fps]
Mar 17 19:46:30 test zmc_dvideo[7271]: INF [Neu: 47000 - Capturing at 25.00 fps]
Mar 17 19:47:10 test zmc_dvideo[7271]: INF [Neu: 48000 - Capturing at 25.00 fps]
Mar 17 19:47:50 test zmc_dvideo[7271]: INF [Neu: 49000 - Capturing at 25.00 fps]
Mar 17 19:48:30 test zmc_dvideo[7271]: INF [Neu: 50000 - Capturing at 25.00 fps]
Mar 17 19:49:10 test zmc_dvideo[7271]: INF [Neu: 51000 - Capturing at 25.00 fps]
Mar 17 19:49:50 test zmc_dvideo[7271]: INF [Neu: 52000 - Capturing at 25.00 fps]
Mar 17 19:50:30 test zmc_dvideo[7271]: INF [Neu: 53000 - Capturing at 25.00 fps]
Mar 17 19:51:10 test zmc_dvideo[7271]: INF [Neu: 54000 - Capturing at 25.00 fps]
Mar 17 19:51:50 test zmc_dvideo[7271]: INF [Neu: 55000 - Capturing at 25.00 fps]
Mar 17 19:52:30 test zmc_dvideo[7271]: INF [Neu: 56000 - Capturing at 25.00 fps]
Mar 17 19:53:10 test zmc_dvideo[7271]: INF [Neu: 57000 - Capturing at 25.00 fps]
Mar 17 19:53:46 test zmdc[6144]: WAR [Can't find process with command of 'zmc -d /dev/video0']
Mar 17 19:53:46 test zmdc[6144]: INF ['zmc -d /dev/video0' starting at 07/03/17 19:53:46, pid = 7823]
Mar 17 19:53:47 test zmdc[7823]: INF ['zmc -d /dev/video0' started at 07/03/17 19:53:47]
Mar 17 19:53:47 test zmc_dvideo0[7823]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:53:47 test zmc_dvideo0[7823]: INF [Starting Capture]
Mar 17 19:53:50 test zmdc[6144]: WAR [Can't find process with command of 'zma -m 4']
Mar 17 19:53:52 test zmc_dvideo[7271]: INF [Neu: 58000 - Capturing at 23.81 fps]
Mar 17 19:55:08 test zmc_dvideo0[7823]: INF [Neu: 1000 - Capturing at 12.35 fps]
Mar 17 19:55:12 test zmc_dvideo[7271]: INF [Neu: 59000 - Capturing at 12.50 fps]
Mar 17 19:56:28 test zmc_dvideo0[7823]: INF [Neu: 2000 - Capturing at 12.50 fps]
Mar 17 19:56:29 test kernel: bttv0: PLL can sleep, using XTAL (28636363).
Mar 17 19:56:29 test kernel: bttv0: timeout: drop=14 irq=345431/345431, risc=0155b024, bits: HSYNC FDSR
Mar 17 19:56:29 test kernel: bttv0: reset, reinitialize
Mar 17 19:56:29 test zmc_dvideo0[7823]: ERR [Sync failure for frame 7 buffer 0(1): Input/output error]
Mar 17 19:56:29 test zmc_dvideo[7271]: ERR [Sync failure for frame 0 buffer 1(1): Input/output error]
Mar 17 19:56:29 test zmdc[6144]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 17 19:56:29 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:56:29 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video0]
Mar 17 19:56:29 test zmdc[6144]: INF ['zmc -d /dev/video0' starting at 07/03/17 19:56:29, pid = 7866]
Mar 17 19:56:29 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:56:29 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:56:29, pid = 7867]
Mar 17 19:56:30 test kernel: bttv0: PLL: 28636363 => 35468950 .. ok
Mar 17 19:56:30 test zmdc[7867]: INF ['zmc -d /dev/video' started at 07/03/17 19:56:30]
Mar 17 19:56:30 test zmdc[7866]: INF ['zmc -d /dev/video0' started at 07/03/17 19:56:30]
Mar 17 19:56:31 test zmc_dvideo[7867]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:56:31 test zmc_dvideo0[7866]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:56:31 test zmc_dvideo[7867]: ERR [No monitors found]
Mar 17 19:56:31 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:56:32 test zmc_dvideo0[7866]: INF [Starting Capture]
Mar 17 19:56:36 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:56:36 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:56:36, pid = 7871]
Mar 17 19:56:36 test zmdc[7871]: INF ['zmc -d /dev/video' started at 07/03/17 19:56:36]
Mar 17 19:56:36 test zmc_dvideo[7871]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:56:36 test zmc_dvideo[7871]: ERR [No monitors found]
Mar 17 19:56:36 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:56:46 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:56:46 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:56:46, pid = 7877]
Mar 17 19:56:46 test zmdc[7877]: INF ['zmc -d /dev/video' started at 07/03/17 19:56:46]
Mar 17 19:56:46 test zmc_dvideo[7877]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:56:46 test zmc_dvideo[7877]: ERR [No monitors found]
Mar 17 19:56:46 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:57:06 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:57:06 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:57:06, pid = 7882]
Mar 17 19:57:06 test zmdc[7882]: INF ['zmc -d /dev/video' started at 07/03/17 19:57:06]
Mar 17 19:57:06 test zmc_dvideo[7882]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:57:06 test zmc_dvideo[7882]: ERR [No monitors found]
Mar 17 19:57:06 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:57:46 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:57:46 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:57:46, pid = 7907]
Mar 17 19:57:46 test zmdc[7907]: INF ['zmc -d /dev/video' started at 07/03/17 19:57:46]
Mar 17 19:57:46 test zmc_dvideo[7907]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:57:46 test zmc_dvideo[7907]: ERR [No monitors found]
Mar 17 19:57:46 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:58:09 test zmc_dvideo0[7866]: INF [Neu: 1000 - Capturing at 10.20 fps]
Mar 17 19:59:06 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 19:59:06 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 19:59:06, pid = 7926]
Mar 17 19:59:06 test zmdc[7926]: INF ['zmc -d /dev/video' started at 07/03/17 19:59:06]
Mar 17 19:59:06 test zmc_dvideo[7926]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 19:59:06 test zmc_dvideo[7926]: ERR [No monitors found]
Mar 17 19:59:06 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 19:59:31 test zmc_dvideo0[7866]: INF [Neu: 2000 - Capturing at 12.20 fps]
Mar 17 20:00:11 test zmc_dvideo0[7866]: INF [Neu: 3000 - Capturing at 25.00 fps]
Mar 17 20:00:51 test zmc_dvideo0[7866]: INF [Neu: 4000 - Capturing at 25.00 fps]
Mar 17 20:01:31 test zmc_dvideo0[7866]: INF [Neu: 5000 - Capturing at 25.00 fps]
Mar 17 20:01:46 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 20:01:46 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 20:01:46, pid = 8016]
Mar 17 20:01:46 test zmdc[8016]: INF ['zmc -d /dev/video' started at 07/03/17 20:01:46]
Mar 17 20:01:47 test zmc_dvideo[8016]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 20:01:47 test zmc_dvideo[8016]: ERR [No monitors found]
Mar 17 20:01:47 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 20:02:11 test zmc_dvideo0[7866]: INF [Neu: 6000 - Capturing at 25.00 fps]
Mar 17 20:02:51 test zmc_dvideo0[7866]: INF [Neu: 7000 - Capturing at 25.00 fps]
Mar 17 20:03:31 test zmc_dvideo0[7866]: INF [Neu: 8000 - Capturing at 25.00 fps]
Mar 17 20:04:11 test zmc_dvideo0[7866]: INF [Neu: 9000 - Capturing at 25.00 fps]
Mar 17 20:04:51 test zmc_dvideo0[7866]: INF [Neu: 10000 - Capturing at 25.00 fps]
Mar 17 20:05:31 test zmc_dvideo0[7866]: INF [Neu: 11000 - Capturing at 25.00 fps]
Mar 17 20:06:11 test zmc_dvideo0[7866]: INF [Neu: 12000 - Capturing at 25.00 fps]
Mar 17 20:06:50 test zmc_dvideo0[7866]: INF [Neu: 13000 - Capturing at 25.64 fps]
Mar 17 20:07:07 test zmdc[6144]: INF [Starting pending process, zmc -d /dev/video]
Mar 17 20:07:07 test zmdc[6144]: INF ['zmc -d /dev/video' starting at 07/03/17 20:07:07, pid = 8052]
Mar 17 20:07:07 test zmdc[8052]: INF ['zmc -d /dev/video' started at 07/03/17 20:07:07]
Mar 17 20:07:07 test zmc_dvideo[8052]: INF [Debug Level = 0, Debug Log = <none>]
Mar 17 20:07:08 test zmc_dvideo[8052]: ERR [No monitors found]
Mar 17 20:07:08 test zmdc[6144]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Mar 17 20:07:30 test zmc_dvideo0[7866]: INF [Neu: 14000 - Capturing at 25.00 fps]
Mar 17 20:08:10 test zmc_dvideo0[7866]: INF [Neu: 15000 - Capturing at 25.00 fps]
Mar 17 20:08:50 test zmc_dvideo0[7866]: INF [Neu: 16000 - Capturing at 25.00 fps]
Posted: Mon Mar 19, 2007 7:11 pm
by cordel
typo should be xawtv -hwscan
Need to install pci utilities package for this to work. For FC pciutils package. But again typo scanpci -v
Posted: Mon Mar 19, 2007 7:15 pm
by Max Steel
-bash: xawtv: command not found
if you think that i need an extra package for this.
PS:
I know, my English is silly.
I'm German.
Edith:
pci utilitis is installed
ok
Quote of 'scanpci -v':
pci bus 0x0000 cardnum 0x00 function 0x00: vendor 0x1106 device 0x3123
VIA Technologies, Inc. VT8623 [Apollo CLE266]
CardVendor 0x1106 card 0xaa01 (VIA Technologies, Inc., Card unknown)
STATUS 0x2230 COMMAND 0x0006
CLASS 0x06 0x00 0x00 REVISION 0x00
BIST 0x00 HEADER 0x00 LATENCY 0x08 CACHE 0x00
BASE0 0xd0000008 addr 0xd0000000 MEM PREFETCHABLE
BYTE_0 0x00 BYTE_1 0x18 BYTE_2 0x88 BYTE_3 0x80
pci bus 0x0000 cardnum 0x01 function 0x00: vendor 0x1106 device 0xb091
VIA Technologies, Inc. VT8633 [Apollo Pro266 AGP]
STATUS 0xa230 COMMAND 0x0107
CLASS 0x06 0x04 0x00 REVISION 0x00
HEADER 0x01 LATENCY 0x00
PRIBUS 0x00 SECBUS 0x01 SUBBUS 0x01
SECLT 0x00 SECSTATUS 0xa220
IOBASE 0xf000 IOLIM 0x0fff
NOPREFETCH_MEMBASE 0xdc000000 MEMLIM 0xddffffff
PREFETCH_MEMBASE 0xd8000000 MEMLIM 0xdbffffff
NO_FAST_B2B NO_SEC_BUS_RST NO_M_ABRT VGA_EN ISA_EN NO_SERR_EN NO_PERR_EN
pci bus 0x0000 cardnum 0x0d function 0x00: vendor 0x1106 device 0x3044
VIA Technologies, Inc. IEEE 1394 Host Controller
STATUS 0x0210 COMMAND 0x0007
CLASS 0x0c 0x00 0x10 REVISION 0x80
BIST 0x00 HEADER 0x00 LATENCY 0x20 CACHE 0x08
BASE0 0xde000000 addr 0xde000000 MEM
BASE1 0x0000d001 addr 0x0000d000 I/O
MAX_LAT 0x20 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x10 function 0x00: vendor 0x1106 device 0x3038
VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
CLASS 0x0c 0x03 0x00 REVISION 0x80
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x08
BASE4 0x0000d401 addr 0x0000d400 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x40 BYTE_1 0x12 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x10 function 0x01: vendor 0x1106 device 0x3038
BASE4 0x0000d801 addr 0x0000d800 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x02 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x10 function 0x02: vendor 0x1106 device 0x3038
BASE4 0x0000dc01 addr 0x0000dc00 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x03 INT_LINE 0x05
pci bus 0x0000 cardnum 0x10 function 0x03: vendor 0x1106 device 0x3104
VIA Technologies, Inc. USB 2.0
STATUS 0x0210 COMMAND 0x0017
CLASS 0x0c 0x03 0x20 REVISION 0x82
BASE0 0xde001000 addr 0xde001000 MEM
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x04 INT_LINE 0x0b
BYTE_0 0x00 BYTE_1 0x02 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x11 function 0x00: vendor 0x1106 device 0x3177
VIA Technologies, Inc. VT8235 ISA Bridge
STATUS 0x0210 COMMAND 0x0087
CLASS 0x06 0x01 0x00 REVISION 0x00
BIST 0x00 HEADER 0x80 LATENCY 0x00 CACHE 0x00
BYTE_0 0x45 BYTE_1 0x00 BYTE_2 0xf0 BYTE_3 0x00
pci bus 0x0000 cardnum 0x11 function 0x01: vendor 0x1106 device 0x0571
VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
STATUS 0x0290 COMMAND 0x0007
CLASS 0x01 0x01 0x8a REVISION 0x06
BIST 0x00 HEADER 0x00 LATENCY 0x20 CACHE 0x00
BASE4 0x0000e001 addr 0x0000e000 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0xff
BYTE_0 0x1b BYTE_1 0xf2 BYTE_2 0x09 BYTE_3 0x05
pci bus 0x0000 cardnum 0x11 function 0x05: vendor 0x1106 device 0x3059
VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller
STATUS 0x0210 COMMAND 0x0001
CLASS 0x04 0x01 0x00 REVISION 0x50
BIST 0x00 HEADER 0x00 LATENCY 0x00 CACHE 0x00
BASE0 0x0000e401 addr 0x0000e400 I/O
BYTE_0 0x01 BYTE_1 0xcd BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0000 cardnum 0x12 function 0x00: vendor 0x1106 device 0x3065
VIA Technologies, Inc. VT6102 [Rhine-II]
CardVendor 0x1106 card 0x0102 (VIA Technologies, Inc. VT6102 [Rhine II] Embeded Ethernet Controller on VT8235)
CLASS 0x02 0x00 0x00 REVISION 0x74
BASE0 0x0000ec01 addr 0x0000ec00 I/O
BASE1 0xde002000 addr 0xde002000 MEM
MAX_LAT 0x08 MIN_GNT 0x03 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x01 BYTE_1 0x00 BYTE_2 0x02 BYTE_3 0xfe
pci bus 0x0000 cardnum 0x14 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
STATUS 0x8290 COMMAND 0x0006
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xde003008 addr 0xde003000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x14 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xde004008 addr 0xde004000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0001 cardnum 0x00 function 0x00: vendor 0x1106 device 0x3122
VIA Technologies, Inc. VT8623 [Apollo CLE266] integrated CastleRock graphics
STATUS 0x0230 COMMAND 0x0007
CLASS 0x03 0x00 0x00 REVISION 0x03
BASE0 0xd8000008 addr 0xd8000000 MEM PREFETCHABLE
BASE1 0xdc000000 addr 0xdc000000 MEM
MAX_LAT 0x00 MIN_GNT 0x02 INT_PIN 0x01 INT_LINE 0x0b
