Page 1 of 1
can't delete more than 185 events
Posted: Mon Jul 17, 2006 2:53 pm
by gnuorder
I have a strange problem with deteting events. It started with a new install of 1.22.0 and I just upgraded to 1.22.2 and it still happens. No matter how many events I select, only 185 get deleted and I can't figure out why. This is a gentoo AMD64 system using the ebuilds to install. Has anyone had this problem and fixed it?
Posted: Mon Jul 17, 2006 4:33 pm
by zoneminder
This form uses 'get' rather than 'post' as it can get refreshed automatically and you get browser messages if you refresh a 'post'ed form. Thus the event ids are appended to the url and I think most browsers have a limit to the length of this. Assuming it is 1024 or so, then divide this by the lenth of your ids plus '&' to get the limit.
It is probably a bug, I think it should probably just indicate 'all visible' rather than the ids when you check all of them.
Posted: Mon Jul 17, 2006 5:20 pm
by gnuorder
If you are indicating the browser, it happens with all browsers and I can delete from a previous system running 1.21.0 and 1.22.0 just fine. Apache version is 2.0.55 and the mysql version is 4.1.14. The old system uses apache 2.0.52 and mysql 4.0.20.
Posted: Thu Jul 20, 2006 3:21 pm
by zoneminder
If you check your httpd access logs when you try these large deletes, do you see all the event ids passed on the request?
