HD is Full
germandms
HD is Full
Post by germandms »
I have zm 1.22.2 in Suse 10 worked without problems, but already full hd, and let work, when entrance to the Web I see east error
Warning: Unknown(): write failed: No space left on device (28) in Unknown on line 0
Warning: Unknown(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php) in Unknown on line 0
How I can make that they erase automatically, not to return to have this problem
thank
Bye
jameswilson
Post by jameswilson »
please read the faq regarding purgewhenful
in fact please search if you cant find an answer then ask i personaly hsve answered this over 10 times now!!
James Wilson
germandms
I cannot enter in zm
Post by germandms »
I cannot enter in zm to use ocion of PurgeWhenFull
RedFlyer
Post by RedFlyer »
I think that you can manually delete some 'events' folders to free some HD space and getting back access to your ZM console.
The path is '/var/www/html/zm/events/x' where x correspond to your monitor number. Go inside and you will see folder named by a number, corresponding to the event number.
Just delete some of them.
This procedure must be confirmed by zoneminder or other people that knows what they are doing :wink: this is just my solution.
Regards,
Oliver
________
Stefano domenicali
jameswilson
i to do this when i forget to set purgewhenful
James Wilson
zoneminder
Site Admin
Post by zoneminder »
Deleting events manually is ok provided zmaudit is running. If it is (which it will be unless you have turned it off) then it will notice the missing event files and remove them from the database. However this may not take place for a few minutes after you have deleted the files so for that period the filesystem and database will not be consistent.
Phil
