I want to reclaim space by purging events in the database which are a certain number of days old.
If I delete them directly from the events database, will ZoneMinder check the frames database and the file system and get rid of the records and directories later?
How to purge old events
yes zmaudit will do this, but i suggest you read the docs as this is explained there
James Wilson
You can easily do that automatically by using filters.
Regards,
Oliver
________
MONTANA DISPENSARIES
Regards,
Oliver
________
