I installed Zoneminder on a debian sarge system.
All seems working.
many thanks to all who made the documentation.
I defined a small zone at the edge of my first camera image.
and then i put the monitor in alarm (moving something inside the zone)
the monitor goes in 'alarm state' and Zoneminder begins to save images in event directory.
My question:
How do I quit alarm status? How is it possible to return to normal status x minutes after an event?
I think I don't understand something may be because my bad english..
best regards
marcel
quit alarm status
Unless your settings are wrong the monitor should return to normal after the alarm has passed plus post alarm image count. If would think that you have your zone set a bit to sensitive
James Wilson
