I picked up two of these at Fry's for $120 each and they are working like a charm (so far). They are indoor cameras, but I mounted them outside under my 2nd story deck so they are protected from the weather.
- 802.11g
- easy windows setup (plug in ethernet cable and run setup software)
- used HTTP 1.1 in ZM for setup
- remote host: admin:password@10.0.0.99
- remote host path: video.cgi
- 320x240 (though it supports 640x480)
- between 5 and 20 fps
Absoutely no complaints so far.
IP CAM: Airlink 101 SkyIPCam250W - Works
- zoneminder
- Site Admin
- Contact:
Re: IP CAM: Airlink 101 SkyIPCam250W - Works
How did you get the wireless to work? The only way I can get a link is via net cable. I've followed the setup to a T and am still getting no love - as soon as I disconnect the cable, no link.
