Page 1 of 1
Broken Mandrake system with Video settings..
Posted: Thu Jul 27, 2006 6:48 pm
by dm
Changed video settings to 1280x1024 @ 60hz, now system will not load.
How do I restore to default so I can reset the video settings?
thanks..
Posted: Thu Jul 27, 2006 7:08 pm
by RedFlyer
Hi !
While your machine is running (with black screen i presume), try to press CTRL-ALT-F1 to get a console access.
Once you have a console access, you can execute 'mcc' and change video (display) settings.
________
BMW OHV V8 ENGINE HISTORY
Posted: Thu Jul 27, 2006 7:15 pm
by rdmelin
Also if you cannot get a console using the above method (if the machine locks for example) you can boot to runlevel 3. At the graphic boot menu press esc and you will get a text boot prompt. Then type "Mandriva 3" and enter.
Then you can login as root and run "mcc". Note that it is lowercase.
Posted: Thu Jul 27, 2006 7:22 pm
by jameswilson
thin k you can also use alt ctrl + and - on numpad to raise and lower the res
Login prompt..
Posted: Thu Jul 27, 2006 8:00 pm
by dm
I got the login prompt, however it shows control chars when i hit ENTER, e.g. shows ^M^M^M
I can't get to a password prompt.
I got to the login prompt by typing the CTRL-ALT-F1, I got to the login prompt with mandrake 3 also.
Thanks for the info BTW, I'm used to SUSE and FC4.
This helps, but I still can't login. I'm using the static profile. Its the Control CHAR issue ..
It won't accept ENTER.
TVMIA
Re: Login prompt..
Posted: Thu Jul 27, 2006 8:07 pm
by dm
dm wrote:I got the login prompt, however it shows control chars when i hit ENTER, e.g. shows ^M^M^M
TVMIA
Hey -- I got in.
The Ctrl-Alt NumLock + and - keys changed the resolution for me, wow! I felt like a Gorilla in a china shop with that resolution! haha!
I got it working @ 1280x1024 x 16 million. I wanted to match it since its on a sw.
Thanks a bunch!!!!
