Where can you specify the USER and PASSWORD for cameras or is one forced to use anonymous access and restrict to # of connections?
In other words, can a username and password be specified in ZM Console for each AXIS Network Camera?
Thanks..
Question regarding AXIS Network Users
pass
user:pass@<ip>
in the host part of the monitor, get it working first without auth then you know there is something wrong with the auth if it then stops
user:pass@<ip>
James Wilson
depends on the camera
James Wilson
have a search for axis as there are various paths. Most people use 206's so id use one of those paths just to get you going
James Wilson
